with a chip, this is not needed.
it is definitely a cheap way to feel more power. that was pretty much before we had any options for tuning. I remember some guys using up to a 22k resistor!
ok.thanks guys.i was hoping it may of got me some more low end torque as its an embarressment on steep pulls with my 13k toy hauler.i have done pretty much everything i can for HP gains besides new injectors.just aint got the 2 grand for swapping them right now.its got a riff raff intake,3 inch down pipe,TPS chip,CAT is deleted.anything cheap i missed?
Maybe go check armature clearance in injectors. If it's tight it won't run right. And the shim kit is under a hundred. I have one to install once rain stops.
