E40D to ZF5
Old Aug 5, 2017 | 12:10 AM
Pinnock's Avatar
Pinnock
E40D to ZF5
I have a 1997 7.3 crew cab long box that I'm wanting to put a zf5 in. I have a 92 7.3 parts truck so just wondering what all I can and can't swap over and do's and don'ts. Thanks in advance.
Old Aug 5, 2017 | 09:51 AM
97-psd's Avatar
97-psd
there are several threads that will be really helpful for you. Search this forum and enjoy the read!
Old Aug 5, 2017 | 03:54 PM
91 Dually's Avatar
91 Dually
I swapped my 97 from a e4od to the zf5. My donor truck was a 93 7.3. I used the tranny, pedals, clutch slave and master. Crossmember, wiring harness, floor pan.
Pretty much every thing except for the flywheel and clutch kit.
I also used the transfer case from the 97
Also had to have my front drivehaft shortened by 5 3/8 inches and rear one lengthened the same amout. The zf is 5 3/8 inches shorter than the e4od.
Old Aug 5, 2017 | 04:38 PM
madpogue's Avatar
madpogue
If the donor is an F350, you should be able to use its front driveshaft. If it's a CC, you should be able to use its rear driveshaft.
KingDeleted
Feb 25, 2022 10:09 AM
e5n_devildog
Feb 5, 2016 03:25 PM
Ferd7.3
Sep 29, 2014 10:11 PM
bmxstreet15
May 13, 2009 07:13 AM
topgunn
Jul 31, 2006 10:07 PM
