Hypertech Programer with 10k mod
Old May 25, 2008 | 02:13 PM
Huntnfooltwo's Avatar
Huntnfooltwo
Is it worht doing the 10k mod with my existing Hypertech program on my 96 Powerstroke.
Old May 25, 2008 | 02:19 PM
ono_55's Avatar
ono_55
I would think that the programer would address the icp also, so i wouldn't do it.
Old May 25, 2008 | 02:38 PM
Huntnfooltwo
Thats what needed to Know Thanks
Old May 26, 2008 | 11:29 PM
1950gmcelc's Avatar
1950gmcelc
I Have A Hypertec Chip In My 95 And When I Tried The 10k Mod I Noticed Quicker Acceleration But I Would Get A Stumbble Under A Load. I Don't Know If The Problem Has To Do With The Chip Or Not Or Maybe Bad Injector Orings But I Dont Know.
Old May 27, 2008 | 02:17 AM
RubberDuck's Avatar
RubberDuck
You can absolutely run a 10k with a hypertek. Those are off the shelf programers, and don't usually max out ICP. I ran one with a superchip with good results.
1950, I noticed the same thing if I went to like a 5.6k. The HPOP just wasn't strong enough to keep up. Maybe your pump was getting weak.
But in the end, you can try it, and see the results. If you don't like it pull it. It shouldn't hurt anything. Worse case senario, replace IPR orings. But I highly doubt it.
Old May 27, 2008 | 04:33 PM
c00nhunterjoe's Avatar
c00nhunterjoe
i'm with duck, run it and see if if your truck likes it, most will with the run of the mill tuners, yours should be a considerable improvement
Old May 27, 2008 | 06:14 PM
1950gmcelc's Avatar
1950gmcelc
How Hard Is A Hpop To Change Out And How Much Do They Cost For A New One?
Old May 27, 2008 | 07:19 PM
RubberDuck's Avatar
RubberDuck
Here's my writeup on the HPOP change to a SD pump. And it costs about $400 for the pump alone. Hope this helps.
https://www.ford-trucks.com/forums/5...ml#post4017748
