2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Help me troubleshoot - interior lights and panels are flashing
Old 08-02-2017, 06:16 PM
TheyCallMeBT's Avatar
TheyCallMeBT
TheyCallMeBT is offline
Hey folks. I have a 2008 Ford Expedition Eddie Bauer. Can use some help identifying an issue with the interior lights. See the video below. The brightness of the green lights on the buttons and dash will go high to low (blinking). Also, the actual interior overhead lights will blink on and off. Lately, they will not come on when I open the door (which they should). But they will sometimes come on if I turn them on manually by turning the dimmer switch for the interior lights all the way up. I checked all of the fuses that could possibly correspond to this, and they were all fine.
I'm thinking it may be the panel dimmer switch itself. By that, I mean the rocker on the right side of this image.
(Not my image, and from a different model vehicle)
Old 08-03-2017, 09:22 AM
alloro's Avatar
alloro
alloro is offline
Received 4,198 Likes on 2,433 Posts
Look for the ground wires behind the passenger kick panel. Make sure they're clean and tight.
Old 05-24-2018, 05:10 PM
TheyCallMeBT
Hey folks. Still looking for assistance in figuring this out. I checked the wiring in the passenger kick panel, from alloro's advice, and everything looked to be ok. I've also checked all of the fuses that could have something to do with it, and they are good.
I updated my original post for clarity. If you could take a quick look at the video (it's short), and let me know if you have any suggestions.
I'm thinking it may be the dimmer switch itself. If so, I believe this is the correct part. If you are able to confirm that, let me know. And also, is ebay the best place to source this, or is there a trustworthy online store that sells it?
https://www.ebay.com/itm/Instrument-...5/252973940148
Thanks!
Edit: found it on Autozone's website, too.
https://www.autozone.com/electrical-...?checkfit=true
Old 03-02-2020, 11:07 AM
Matt Watkins's Avatar
Matt Watkins
Matt Watkins is offline
Any updates?
I am having the same issue with my 07 Ford Expedition a month after replacing the smart junction box. The tire pressure light is stuck on as well. Sounds similar to your issue so I’m inquiring if you found a solution
Old 06-30-2021, 08:57 PM
williamtg's Avatar
williamtg
williamtg is offline
Any update? I have the same problem in my Navigator 08
Les C
6.7L Power Stroke Diesel
08-11-2018 05:03 PM
Grahams
04-27-2011 03:38 PM
peytonkristen
12-09-2010 05:47 PM
Suomi Powerstroke
12-02-2009 02:53 AM
bobj49f2
03-06-2006 05:17 PM
Quick Reply: Help me troubleshoot - interior lights and panels are flashing
