This is video where you can hear a noise coming from transmission. C6 type, this is sound before oil change and after oil change it is little better but i think it is clutch. I made total flush whit oil change. Rear pump? i tried whitout belts, i gonna chek flywheel.
Cool car.I bet she's a pleasure to drive.I take it the noise your hearing is the whining sound? Sounds like it could be the pump gears.You would need to pull the trans and then the pump to inspect it though.Since the old C6's are so cheap,you may just want to run 'er for all shes worth and then have it rebuilt or replaced when it fails.Of course,make sure of the basics,that it's full of trans fluid and not sucking air or something.
Thank you, i tought that sound makes clutch, the fluid level is proper, and when i removed cooling pipes( home made fluidflush), the oil flow was constantly smooth. There for i wont suspect trans fluid pump. After fluid change the whining went down, perhaps there is some air in it
where can it suck air, this vacuum thing or the other thing whats on the side on trans ?
opened service port on the gear box and no oil camed of it, then it shows that seal is holding oil in.
how i can test for trans air tightness ?
reading today this thread, https://www.ford-trucks.com/forums/8...converter.html
maked me wonder, if there is issue whit torque converter at all, cause sound comes clearly from bellhousing.
and then question how i know what torque converter i need ?
I just my tranny and it makes similar to the same sound and my truck won't go
I just rebuilt my training to see six in the state of New York forward and it makes similar to the same sound and I was wondering if it might be a bad pump
