strange noise when accelerating from c6 trans
Old Apr 19, 2010 | 07:53 PM
soundguy567's Avatar
soundguy567
I just recently bought a 1976 F100 with a 360 and c6 trans. I had a noise that I could of swore was the power steering pump, but after replacing it and the noise still was there I knew I was wrong. It only makes the noise when I accelerate and it is coming from the trans. I heard it this morning while the truck was warming up with the choke so I crawled under and heard it there. It is high picked almost like a bearing or a pump that is sticking. any ideas?
Old Apr 19, 2010 | 07:56 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Probably the transmission oil pump going out. Is the oil bright red?
Either way, since you just bought it might be a good idea to dump the fluid and add fresh Type F and go from there.
Josh
Old Apr 19, 2010 | 08:29 PM
soundguy567
The fluid is freshly changed by previous owner, it looks clean and full
Old Apr 19, 2010 | 09:16 PM
G4mb1t's Avatar
G4mb1t
i had the same problem, found out the carrier bearing and the u joints where bad on my d-shaft
nothercrash
17
Jan 13, 2011 06:00 PM
chad85
Oct 4, 2007 01:27 AM
Ray_K
Sep 19, 2006 07:56 AM
fish1174
Aug 17, 2003 12:56 PM
