Knock Sensor
Old Sep 6, 2003 | 11:42 PM
mrit's Avatar
mrit
Knock Sensor
I did a koer test on my 1986 bronco with EFI 302 and came up with a code. Its for the knock sensor. I have looked all over the engine but couldnt find one, maybe im just blind. But does anyone know where this is? Any way of testing it to check if the sensor it bad?
Old Sep 7, 2003 | 12:43 AM
DW2455's Avatar
DW2455
Knock Sensor
My under standing is it on the back of the block kinda to the pasenger side, its a PITA to get to. there shoud be a tes procedure in the haynes book. Good luck DW
Old Sep 7, 2003 | 12:49 AM
90f150moneypit's Avatar
90f150moneypit
Knock Sensor
This may sound funny but my Chilton's method for testing is to rap on the block with a hammer or such and see if it retards your timing. lol
Old Sep 8, 2003 | 12:28 PM
mrit's Avatar
mrit
Knock Sensor
Thanks alot!
Old Sep 9, 2003 | 03:19 PM
bigric's Avatar
bigric
Knock Sensor
That's the same procedure prescribed by Ford in their service manuals.
Here's the first part of your knock sensor test. From here, it branches out three ways. Let me know what you get and I'll post the follow-up:
DG1 SERVICE CODE 25/225: GENERATE KNOCK MANUALLY
Service Code 25/225 indicates that the Knock Sensor (KS) signal to the processor was not sensed during the Dynamic Response Test after the ID code in Key On Engine Running Self-Test.
Possible causes are:
-- Damaged knock sensor.
-- Open or shorted harness.
-- Damaged processor.
NOTE:
Since knock conditions are sensitive to fuel, altitude and weather in addition to ignition timing, perform Step DG1 before servicing any components.
l Locate knock sensor and prepare to rap/tap the engine block close to the sensor with a 4 oz. hammer.
l Run Engine Running Self-Test (engine must be at operating temperature).
l Tap the engine block close to the knock sensor immediately after the Dynamic Response code is given.
NOTE:
It is not necessary to "goose" the throttle. Ignore all other codes except Code 25/225.
l Is Service Code 25 or 225 present?
Yes
GO to «DG2».
No
Knock sensor system OK. RERUN Engine Running Self-Test and SERVICE any other codes.
DG2 CHECK KS CIRCUIT VOLTAGE
l Key off.
l Disconnect knock sensor.
l Key on, engine off.
l Measure voltage between KS circuit and SIG RTN circuit at the Knock Sensor vehicle harness connector.
Voltage is between 1 and 4 volts
GO to «DG6».
Voltage is less than 1 volt
GO to «DG3».
Voltage is greater than 4 volts
GO to «DG5».
bigric's Avatar
bigric
Knock Sensor
NOTE:
NOTE:
Yes
GO to «DG2».
No
l Key off.
GO to «DG6».
GO to «DG3».
GO to «DG5».
Old Sep 10, 2003 | 05:26 PM
Border3899's Avatar
Border3899
Knock Sensor
Do a search using Knock Sensor it'll come up with some thread's on where it's located!
rock2610d
Modular V10 (6.8l)
30
Jul 8, 2016 07:54 PM
FordRick
Aug 3, 2013 12:46 PM
z 97ford1
1997 - 2003 F150
Jun 21, 2013 12:04 AM
gcpommom
Aerostar
Oct 15, 2011 08:53 PM
fordsrus
Jan 25, 2001 11:00 AM
