302 -> 351 head swap
Old Sep 9, 2003 | 10:00 AM
MerrickJ's Avatar
MerrickJ
Question 302 -> 351 head swap
I was wondering if it was possiable to put 302 heads on a 351 block.....because I've got a pair of rebuild 302 heads and am just missing the block. Would it be beter to simply stick with the 302 or upgrade to the 351....I'm looking for low end torque for towing and such. If anybody has suggestions they'd be greatly appreciated.
Old Sep 9, 2003 | 10:40 AM
DW2455's Avatar
DW2455
there are some castings better than others but if its a stock motor you wont notice much difference, as long as the heads are both windsor style heads it wont make much differnce 302/351. DW
Old Sep 9, 2003 | 05:01 PM
ecarter50's Avatar
ecarter50
302 uses 7/16" head bolts, 351W uses 1/2". You will have to drill out the holes to fit.
Old Sep 9, 2003 | 08:23 PM
jwtaylor's Avatar
jwtaylor
Actually if your motor (351) is somewhere in the mid 80+/- up it already has a 302 design head, part of the reason they are not favored by anyone. Now if you are talking 302 aluminum aftermarket or gt-40/and or p then go for it. The aftermarket heads usually throw the designation for their head into the 302/351 classification. If the heads have been opened up ported then it depends on how they flow, since you already have them why not they are free but if they are stock its not worth opening up the bolt holes to make them work. This is my opinion, good luck building the engine
Old Sep 10, 2003 | 06:54 PM
fordtrks4fr's Avatar
fordtrks4fr
after 76 69cc head was a 69cc head and the bolt holes were the only diff. i wouldnt run a longer duration cam with them though, there isn't enough compression there, would work good for a low duration for lots of torque
tjstruckin
Oct 28, 2011 12:41 AM
letsgomuddin85
22
Mar 21, 2009 10:41 PM
joeKyTN
13
Mar 10, 2008 01:26 PM
v10squirrel
Jul 10, 2007 08:54 PM
jc78
Apr 8, 2001 11:28 PM
