Knock Sensor Replacement
Old Aug 2, 2013 | 10:40 PM
FordRick's Avatar
FordRick
I have a 2007 navigator with very low miles (30,000). The engine light came on with a code PO330 knock sensor 2 circuit malfunction (bank 2).
So looks like I have to find the darn thing somewhere in the intake manifold, test it for impedance or a bad wire \connection and or replace.
Are there any instructions or ideas on how best to proceed without taking it into the shop?
Old Aug 3, 2013 | 11:57 AM
alloro's Avatar
alloro
Both are under the intake, so the intake has to come off. BTW, with the intake off it's a great time to replace the spark plugs.
Anyway, view the attached PDF and numbers 3 an6 are the 2 knock sensors.
File Type: pdf
Old Aug 3, 2013 | 12:19 PM
FordRick's Avatar
FordRick
alloro,
Thank you for the reply. Any idea how long or how difficult the job is to get to these sensors?
Old Aug 3, 2013 | 12:26 PM
alloro's Avatar
alloro
That would depend on your skills and your tool collection. Without knowing that I'd say3-5 hours.
BTW, before you pull the intake, you might want to access the connectors for the 2 sensors and swap them just to see if the code moves to the other side. The sensor could be good and you could be having a wiring issue. If it's a wiring issue then you would've pulled the intake for no reason.
Old Aug 3, 2013 | 12:46 PM
FordRick's Avatar
FordRick
Swapping the leads is a great suggestion. Is it difficult to get to the sensor leads to do the swap?
I have a pretty robust tool collection but 3 to 5 hours is quite a bit. Do you know what the shop time allows for this procedure?
shinyFord
Apr 30, 2009 07:48 PM
Swede1
Aug 29, 2007 08:42 PM
bomberchamp
Modular V8 (4.6L, 5.4L)
Jul 11, 2005 10:35 AM
free90xlt
Aug 9, 2004 09:54 AM
jpjshy13
Apr 25, 2004 10:00 AM
