To keep my drill index prestine, I have drawer of well used bits that can be sacrificed without concern.
That said, I burned up a few right away. Against my better judgement, bought a carbide bit which snapped almost immediately as I expected. ( Really should only use them in a drill-press) Used up 2 new colbalt bits. The set screw must be near 60 C. Ruined my high quality easy-outs...... Got er done but now it's time to sacrifice a few of my old taps........
When I was disassembling my 50, I could not brake the set screw loose. I took my map gas torch and held it to the hole to heat the screw for a little bit and I was able to turn it right out.
I am presently working on a 40 Ford coupe and it has the same dock lock retainer lash up as the truck. In my case the PO had repaired the door panel around the lock and had removed the collar and set screw tube. I found a replacement for the drivers door at Dennis Carpenter. He makes a kit to add a lock to the driver's door and part of the kit is a new sleeve/collar assembly. I used this kit for the driver's door and welded up the hole on the passenger side.
May I ask what this set screw does and why one would need to loosen it? I didn't even know this was a problem...now I'm scared. heh
Modern cars/trucks use a "U"-shaped spring clip to hold the door lock cylinder in place. Early Fords, including my 1940, had a sleeve on the inside skin of the door into which the door lock cylinder slid. This sleeve has a set screw (which is accessed through a hole in the door jamb) that is turned to hold the door lock cylinder in place or to remove the cylinder. Rather arcane setup but I am sure that it seemed like a good idea at the time. Since the door lock cylinder is an item that is seldom removed/replaced, this setscrew corrodes, freezes, whatever you want to call it and becomes a PITA to anyone who wants to remove it.
The set screw holds the key lock in the door and must be removed if you want to remove it. In many cases such as mine, somebody had previously tried to remove it and buggered up the hex rendering it useless.
