That dreaded set screw
Old Mar 19, 2014 | 08:46 PM
toby tough's Avatar
toby tough
So there I was trying to get the door latch mech. out of my passenger door when all of a sudden I remember the set screw for the lock. I've got all the screws out holding the mech and handle parts out, so I figure I'll hose it with some PB and try it tomorrow. Out of curiosity and only 10 minutes of soaking I put the allen wrench in there and give it a try. It turns with moderate effort. Yay! But I still can't get the contraption out of there. Is there a trick to it or am I going to have to take the regulator for the window out first? I think I might have to but want to make sure first. I suppose if I do I'll take the door off and lay it down while I operate on it. Any ideas would be very cool.
Old Mar 19, 2014 | 09:16 PM
ALBUQ F-1's Avatar
ALBUQ F-1
There is a screw on the jamb that holds the outside handle assembly in, have you removed the handle? Is it the lock cylinder you can't get out, or the latch mechanism?
Old Mar 20, 2014 | 03:07 AM
dmack91's Avatar
dmack91
If it is the door lock you are asking about, once the set screw is out, the lock just pulls out. Haven't taken a latch mech out so don't know on that one.
Old Mar 20, 2014 | 07:11 AM
toby tough's Avatar
toby tough
Hey guys, got the lock out.I'm trying to get the latch mech. out so I can fix the hole the rod for the outside handle goes through. Been trying to roll the wjndow up or down to get the inside handle piece out of it's hole. Didn't want to cut the rivet on the rod that connects the two. Suppose if I did cut the rivet I could replace it with a stove bolt and a nylock nut. Thanks for the replies.
Old Mar 20, 2014 | 09:36 AM
ALBUQ F-1's Avatar
ALBUQ F-1
No, don't cut the rivet!! It's not easy, but by rotating the plate at the inside handle, you can worm it out.
Old Mar 29, 2014 | 07:30 PM
toby tough's Avatar
toby tough
Well I finally got the darned thing out. Thanks for the tip Ross.Tried two separate times and got frustrated. Didn't want to break the window and all that. The back of my hand is healing nicely. Went back this am and it popped right out. So now I know why the door handle wouldn't work. Anyone have an idea how to fix this or is it a replace it sort of thing?
Old Mar 29, 2014 | 08:00 PM
FortyNiner's Avatar
FortyNiner
What was the issue that started the disassembling? Any functionality at all? There are wear surfaces you'll want to inspect.
Old Mar 29, 2014 | 08:47 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I don't think you can really repair that part, maybe if you are a real skilled welder. I don't know anyone selling the individual parts of the latch.
Old Mar 29, 2014 | 09:40 PM
toby tough's Avatar
toby tough
The outer handle would spin around with a pause as the rod that passes through the hole tried to engage what was left of the square opening it went through. I'll have to fiddle around with it tomorrow and see what I can do for it. The rods are close to the same size as the old school door *****. I have a few of those sets in the shop. The only thing about those is that the part that takes the rod for the **** is cast iron.
oscajo
Aug 27, 2015 06:20 PM
aussiecowboy
May 29, 2012 10:31 PM
Leemakesmepee
Aug 24, 2011 06:24 AM
bbearls
May 17, 2007 07:47 AM
bigmanxlt
1997 - 2003 F150
Mar 19, 2004 07:05 PM
