Loose Steering
Old Sep 20, 2017 | 01:57 PM
  #46
05MilMachine's Avatar
05MilMachine
typing "overload spring" into google and then hitting image results tells me that calling it anything else might CAUSE confusion. I think that name has been well established.
I do wonder if these aftermarket springs would test to the same rating as the factory springs they are supposed to replace. I realize only Ford cares what a X code spring is and that could even change from year to year and only Ford would care. However when you put a number to a spring, that is something you can compare. Say comparing the ATS springs ,SD truck springs and a factory C code spring. Would all three really be the same?
Old Sep 20, 2017 | 08:06 PM
  #47
Stewart_H's Avatar
Stewart_H
Stewart
Old Sep 20, 2017 | 08:15 PM
  #48
RobRoss's Avatar
RobRoss
The same only in the sense that they are springs.
Old Sep 21, 2017 | 07:22 AM
  #49
ATS Junior's Avatar
ATS Junior
SPONSOR
If the springs are being manufactured within the standards of the Spring Research Institute then yes they "should" be the same but that is not always the case. More and more we see junky and recycled steel being used and junk rubber components being used. I can't speak for other people's springs (especially those companies that drop ship everything) but we would put our springs up against any Ford Spring.
Old Sep 21, 2017 | 08:46 AM
  #50
RobRoss's Avatar
RobRoss
When I swapped my springs I wanted new Ford springs but if/when I do it again, I would definitely buy from ATS. If ATS springs were even marginal, we would have heard about it already.
Thank you.
Old Sep 21, 2017 | 08:49 AM
  #51
wpnaes's Avatar
wpnaes
Thanks Jr for clarifying, I would think recycled steel could be made into high quality springs with the right process. Maybe that's not cost effective compared to virgin steel. I just assumed most new products made of steel had some recycled steel mixed in. Kinda like that corn EtOH mixed in the gasoline.
Old Sep 21, 2017 | 09:27 AM
  #52
pirate4x4_camo's Avatar
pirate4x4_camo
Are you a member ?
If so you might want to contact them and let them know your company is not listed on their member register.
0351mike
1966 - 1977 Early Broncos
22
Oct 14, 2015 08:33 PM
boilermanc
Jan 3, 2015 02:04 PM
TSmylie
Aug 5, 2014 08:04 AM
midsouth
Apr 6, 2012 07:01 PM
jeffzoot
Dec 4, 2005 07:53 PM
