Loose Steering
"At highway speeds (with no disturbances) one should require only slight pressure changes with no tendency to wander. When there is too little caster there is actually a dead zone between left and right which we are describing as "loose steering"."
https://www.rv.net/forum/index.cfm/f...print/true.cfm
From the factory the front and rear leafs are simply too weak for the weight of the rig. These leafs allow too much flex while cruising down the road. This amplifies any and all variations of the road and body movements.
My last X, and my current X can be driven with 1 hand (fingers really) with almost zero slop. Below is my list of items to fix/check and the order I'd perform.
1. tire pressure
2. Ball joints
3. Steering linkages
4. new leafs front and rear
5. steering damper
6. very very last...adjust the steering box
If you are going to claim that the Ford engineers used the wrong spring rate for the leafs then please share with us your idea of the correct spring rate ?
Are the springs strong enough to hold the vehicle weight and perform tasks such as towing? Absolutely.
Are the springs too soft and deliberately designed to provide a "Soccer Mom" ride from the factory? Absolutely
This has been discussed ad nauseum in this forum for 15+ years. Many people have discovered that if your replace the leafs with Superduty leafs (not modified) you see better handling characteristics. I personally have done it twice. This 2000 and a 2002.
And yes, I absolutely think the front springs are utter garbage out the gate. F-250s don't have to deal with axle slap. You can read forums posts from early 2000's about this. And it just gets worse and worse with age. Superduty with a PSD occasionally see this after years and years of hard abusive duty. Not just pavement cruising like 99% of X's perform
There's a huge difference between Brent and Camo's posting when it comes to backing up claims.
In this case I believe it's just a matter of semantics, intent, and specificity when it comes to a claim about Ford using springs too weak for the Ex.
They obviously weren't too weak, and while the end user (all of us) obtains what we feel is a general consensus that the suspension is much improved when we swap springs, the act of swapping to a "better" spring doesn't prove Ford used springs too weak for the Excursion.
Stewart
a simple answer of what spring rate you think is best was all I was looking for.
Ford engineers spec'ed a spring setup on the Ex to meet certain parameters, namely they wanted a lower ride height so they used a spring with less arch.
the factory spring rate is 380 lbs per inch front and 410 lbs in the rear and the springs have about 5" of wheel travel.
the f250 springs on the other hand have 8' of travel and depending on which of the 6 diffrent springs has anywhere from 350 to 410 while the rears have a 320/670 dual rate.
any of those springs can provide the same ride quality as a stock Ex since your ride quality is largely determined by the shocks.
the take away is that the Ex doesn't have "weaker" springs, they have springs with less arch. Less arch is going to give less wheel travel and when you have old worn shocks this is going to allow the Ex to bottom out onto the bump stop.
bottom line is "better handling" is not achieved from stiffer springs, it is derived from a combination of spring rate, wheel travel, shock tuning, and center of gravity.
the real challenge is defining what "better handling" means to you and selecting which components to use to achieve that. the best way I know of to do that is by understanding or "justifying the engineering"
excursions tend to have more wander complains then the F250 and that is attributed to the geometry of the flatter front leaf spring loosing caster when it sags, but the 250 springs sag just as much over time and plenty of F250's wander. The main culprit there is the wide margin of the caster spec ford uses.
loose steering,vibrations and death wobble is a common trait that is inherent in the design and components used on both the Ex and the F250
Knowing the rate and length we when can now modify the Ex to better suit our needs. Some may want increased payload, others may want altered ride heights, and other may want better on or off road handling traits while others are perfectly happy with the way ford designed it but need to fix some worn out parts.
Although I've never been able to prove this, I suspect the Excursion spring eye bushings are softer than Super Duty. I think this adds to the issues that some folks talk about. I'm talking about spring eye bushings as delivered from the factory, not replacement.
Anadotely, all the Excursion leafs I have taken off have had at least one bad bushing. Usually the front passenger which is also the side that the bump stop gets blown off first. Mostly because drivers naturally avoid hitting pot holes on the drivers side and are not as good at missing road hazards on the side with less visibility. Also why the right rear tire is the most common tire to get a flat.
