Loose Steering
spent some quality time in Mecca but this is the only pic I got because they sequester phones/cameras for the cool stuff.
There's a huge difference between Brent and Camo's posting when it comes to backing up claims.
In this case I believe it's just a matter of semantics, intent, and specificity when it comes to a claim about Ford using springs too weak for the Ex.
They obviously weren't too weak, and while the end user (all of us) obtains what we feel is a general consensus that the suspension is much improved when we swap springs, the act of swapping to a "better" spring doesn't prove Ford used springs too weak for the Excursion.
Stewart
My truck still does not steer perfect and still wonders some. Driving the truck takes more concentration than it should.
The only thing it can be is the CASTER. My next step is to take it to the alignment shop and ask for 5 deg of caster. Don't know what else to do...
Further, here are a couple pictures of my rig with the rear axle loaded to 7160 lbs according to the cat scale I weighed it at:
You are going to have a hard time convincing me that these springs are the same but longer.
The problem with "aligned to factory specs" is that those specs have a wide margin. Caster 3.5* +\- 2* Camber .025* +\- 1* Toe .003* +\- .25*
You can have foul handeling Ex and be within spec.
It could be as simple as a slight toe out adjustment, but it is likely caster.
If you are on stock front springs what is your measurement from the center of the wheel hub to the bottom of your fender arch ? Just curious how much your springs are sagged ? Also what tire pressures are you running front and back ?
simple comparison
ford specs the Excursion rear spring rate as 410 pounds per inch. and a rating of 2275. simple math shows that 410 lbs inch x 5.5. inch = 2275 pounds
so there is the Excursion 5.5" of travel
Ford spec on the B code F250 spring is 320/670 rated for 3000 pounds.
the main leaf pack of the B spring is rated at 320 lbs per inch ( compared the the excursions 410) and we can see from looking at the engineering drawings that the overload leaf does not come into play for the first 5" of travel.
That puts the B code at 320 lbs inch x 5" = a "rating" of 1650 pounds. ( graph shown is copied from engineering blueprints )
However the Mod B spring most people build uses the bottom 2 leafs of the Ex spring. here is where you have to take it on faith since I don't have both springs in front of me to measure but since you live close I will be happy to come over to your house and we can measure and calculate together ( ill bring the beer ). The Top 4 leafs from the Excursion (which has a total of 6 leafs ) and the 4 leafs from the B code are both 320 lbs inch springs.
Adding the Bottom 2 leafs from the Excursion pack onto the B code pack increases the B's spring rate from 320 lbs inch to 410 lbs inch the same as the excursion.
Since the B code spring has more travel at 7.1 inches you can take
7.1 travel X 410 lbs per inch = 2911 rating ( what it takes to compress the spring to its design limit, i.e. flat )
Now the overload.
since we know the Stock B has a spring rate of 320/670 we can subtract and come up with the overload leaf has a rate of 350 lbs inch.
This would give the typical B mode spring a rate of 410/760
since we know that the overload spring only adds spring rate for the last 2" of travel we can figure the rating as
410 x 5 = 2050
760 x 2 = 1520
total rating = 3570
fell free to ask question
Stock G code Excursion
Main pack spring rate 410 lbs per inch
Main pack travel 5.5 inches
Main pack "rating" 2258 lbs
Over load spring rate 0
Over load travel 0
overload rating 0
Rating 2258 lbs
Stock B code F350
Main pack spring rate 320 lbs per inch
Main pack travel 5.1 inches (7.1" total )
Main pack "rating" 1632 lbs
Overload spring rate 670 lbs
Overload travel 2 inches
overload rating lbs 1340
Rating 2971 lbs
Mod B code
Main pack "rating" 2091 lbs
Over load spring rate 760 lbs per inch
Over load travel 2 inches
overload rating 1520 lbs
Rating 3611 lbs
Call the overload spring, the "secondary rate" to avoid any confusion for those who use the pick-up overload spring in their main packs.
I agree that one needs some faith with the Ex spring calcs. I know you know this but for clarity sake...Even though the drawing is linear, actually linear for all leaf springs since they are tested at only a few load points. The reality is the rate is progressive and one rate rolls into the next but we don't have any load points in between. If it was linear like the drawing, the passengers would know when the second rate engaged! I will venture to say that the two small Ex leaves do not add much to the rate at light loads/lower deflection...but for the sake of conversation, this is all we can do is to make the "linear" assumption. Nice job with the math!
Lastly, was this a typo?
410 x 5 = 2050
760 x 2 = 1520 should be 670 (avg rate per dwg)x2 or 1340, total load rating of 3390?
total rating = 3570
Now the overload.
410 x 5 = 2050
760 x 2 = 1520
total rating = 3570
Typo, no.
On the stock B code the secondary rate of 670 is achieved by adding the 350 lb rate of the 5th leaf to the 320 rate of the main pack.
On the mod B the main pack is 410 so add the secondary rate leaf at 350 and you get a 760 secondary rate. Secondary travel is still 2" of travel so 760 x 2 = 1520
As far as the passengers knowing when the secondary engages. I'd beg to differ, it's that hard hit you feel in the seat right before you slam your head into the roof.
If you keep the ratio of the secondary to the primary rate close to 2, it's very subtle. This is one of the reasons I chose my SRW C codes. I have a column in my spreadsheet that calls this out. From memory one of the worst springs is the F code, ratio of 2.33 IIRC.
Typo, no.
I've wondered if the factory bump stops use the same formula, I use an air bump and the rate can be adjusted by changing the pressure. I've never calculated the rate but it is pretty obvious when it is to high.
