Viberation
Old Jul 31, 2017 | 10:06 AM
sonny1965's Avatar
sonny1965
Viberation
Good Morning everyone
I have just purchased a 2013 f150 supercab 5.0
truck has 53000 miles on it. I have known the original owner
it has a brand new set of Michelin tires as it had on it from the factory
same size and same model
I have taken the truck in and had the tires rebalanced twice
as I increase the road speed to 45 mph the viberation starts
and is felt in the seats and increases and gets really bad at 55 mph
then it decreases a little but still viberates up to highs speeds
if I look in the rear view mirror the left rear fender looks to be
moving up and down and the right rear fender looks not to have
any movement.
I would like you guys to give me some ideas on what to look for?
Thanks Sonny
Old Jul 31, 2017 | 02:31 PM
Turbo Dog's Avatar
Turbo Dog
The mirror may be misleading if you have a vibration that you can feel. It can shake the mirror causing a distorted view.
If the tires have been balanced twice, did they find that they are out of balance each time they test them? If so, there may be something loose inside one or more of the wheels. To find out if there is, spin the tire on the balancer and balance it as it indicates. Then manually rotate it slowly for about a half turn and spin balance again to see if it stays in balance.
Otherwise, try riding in another vehicle next to the truck and watching it as it goes down the road to see if you can identify what is shaking.
Old Aug 1, 2017 | 06:55 PM
Toledo's Avatar
Toledo
rotors may be warped? have you got an alignment? check ball joints tie rods... jack up your truck and leave em on jack stands and spin the tire on your truck... if its been rebalanced twice it might be something on your truck.. spin your wheels an try to see if there is any rubbing o any resistance while youre doing this.
Old Aug 2, 2017 | 06:14 AM
WXboy's Avatar
WXboy
Typically, the vibrations on these trucks is due to the craptastic rear shocks and the outboard mounting position of the shocks that Ford uses. Install some much better rear shocks and usually it'll go away or at least be greatly reduced.
I guess it could be a bad wheel, bad tire, sticking brake caliper or shoe, bad U-joint, etc. But, it's usually the shocks on these trucks.
Old Aug 14, 2017 | 01:07 PM
sonny1965's Avatar
sonny1965
Well after the fourth try at the tire shop to rebalance all the tires and wheels
and checked the alignment the truck did a little better. I got up under the
vehicle myself this weekend. I first checked to see if it had any slack in the driveline
at the rear end everything is tight, checked the center section and the carrier bearing
everything is tight. Checked the front driveline at the rear of the transmission loose.
I called the local Ford Dealership and have an appointment for them to look at it
tomorrow to check why it has so much slack in the output shaft of the transmission at the first universal joint. Wish me luck I hope they will cover it in the power train warranty.
Old Aug 18, 2017 | 03:50 PM
sonny1965's Avatar
sonny1965
Well gonna give you an update on the situation. Truck went to the dealer and it sat
there for 2 days and they called me the third day and said they can"t duplicate the
problem. I told them I will be there tomorrow between 9-10 after the traffic dies down
to road test it with whom they desire. Road tested the truck with the service manager
got on the interstate and increased the speed slowly to approximately 55 mph and I
asked him does he feel the vibration. He didn't respond I could see him start thinking. I left the road speed the same and asked him if he wanted me to go on a
smoother part of the interstate at this time it was about another mile or so. I asked
him again do you feel what I feel in the seats and in the floorboard and he said yes
I feel the vibration. Do you want me to continue on with the road test or do we need
to turn around and go back to the dealership. He said turn around and go back to the
dealership. I have called today and left him a message to call me but he has not
returned my call. Will keep you informed on what they come up with the source of
the vibration
Old Aug 18, 2017 | 07:10 PM
zxwut?'s Avatar
zxwut?
the vibration
On the plus side, he admitted he felt something. I don't know if that means anything or not, but it appears it could be headway. Good luck!
Old Aug 20, 2017 | 01:31 PM
Siberexpress's Avatar
Siberexpress
I had a massive vibration on my 03 after putting on a new set of ADR wheels and Toyo Tires. The tire shop after re-balancing the tires and wheels for the 3rd time said I had a problem with one or all of the wheels or tires.
Took it to a shop that had a road force balancer and road force balanced them, turning all 4 tires on the wheels to the correct spot and removing the 32 ounces of weight and balancing all 4 with less than 5 ounces.
makohon
Escape & Escape Hybrid
Oct 29, 2013 11:27 AM
rustranger07
2004 - 2008 F150
15
Oct 17, 2011 05:15 PM
SoCar72
Aug 7, 2010 03:28 PM
scooter81
Apr 28, 2010 02:58 PM
xjcamaro89
2004 - 2008 F150
18
Jun 18, 2009 01:08 PM
