90 f150. Installed new fuel pump. I can hear it run, but not getting any fuel. Lines are disconnected ahead of the filter and not getting any gas to come out. Could the new pump be bad?
Need more information.
Is this a factory two tank truck?
If so has one tank been removed?
If so what was done with the two fuel lines that went to the removed tank?
I replaced the pump. It has two wires, red and black. I spliced them back together the same way, red to red, black to black. Then it just has a plug on the outside of the tank.
