Wrong fuel pump?
Old Jan 26, 2015 | 05:35 PM
Beachboss's Avatar
Beachboss
Wrong fuel pump?
I just replaced the aft fuel pump on my 1988 f250. The previous owner had removed the old pump so I can't compare but the new pump doesn't seem to reach the fuel. I double checked to see if I ordered the right pump and I did. Is it possible I have a oversized tank? There is five gallons in the tank and it reads empty. And when I look thru the vent hole, I can see the fuel screen is barely touching the fuel. Any ideas?
Old Jan 26, 2015 | 06:24 PM
GNR22's Avatar
GNR22
I suggest putting more fuel in so it reaches the pump pickup.
Old Jan 26, 2015 | 10:40 PM
Doostien's Avatar
Doostien
They do make an oversize rear tank, but I think it holds more than 5 gallons and it takes up the spot where the tire hanger used to go. I'm pretty sure its twice the size.
Old Jan 27, 2015 | 08:29 AM
rla2005's Avatar
rla2005
The aftermarket tank mentioned previous typically holds~38 gallons.
FWIW..my old '92 F350 with a 19 gallon rear tank would also register empty with ~5 gallons left. It was annoying. Your fuel pump assembly should reach to the bottom of the tank.
Old Jan 27, 2015 | 01:10 PM
GNR22's Avatar
GNR22
It doesn't pick up fuel from the bottom of the tank because that is where all the junk and debris settles.
Old Jan 27, 2015 | 02:15 PM
rla2005's Avatar
rla2005
Perhaps I should have said close to the bottom. There is no reason why the FDM in the tank now should not be able to draw fuel if it has 5 gallons in it. My old '92 would read empty at ~14 gallons used but I have driven it many times until it ran out of fuel in another 40-50 miles.
Old Jan 27, 2015 | 02:29 PM
Beachboss's Avatar
Beachboss
Thanks for the replies. it could be a 19 gal. tank and a 15 gal. pump assembly.
Any way I also have a 91 that I will have the bed off shortly for a dumpkit install. When I do I'll pull that pump and compare.
jemini
Oct 13, 2018 02:42 PM
JetMech07
Jun 15, 2012 06:27 AM
moose94
33
Jun 30, 2005 12:03 AM
tHeCoS
1978 - 1996 Big Bronco
Nov 2, 2004 08:46 PM
lentz321
Mar 17, 2003 05:53 PM
