fuel problems
Old Dec 9, 2012 | 05:48 PM
mikey7420's Avatar
mikey7420
fuel problems
I have a 1977 ford f150 with 302 (5.0) in it. I have problem it is not pumping fuel from the tank to the engine. so i get new fuel pump for it. install it and nothing. i pull tank out and clean it up make sure the lines are clear. set the motor at top dead center. put everything back together and test everything again and nothing. i buy a electric pump and still nothing. will pump from gas can but not from the tank i have 7 gallons of gas in the tank should be enough right to get fuel from the tank to the engine. what else can i try to find out what the problem is.
Old Dec 9, 2012 | 06:25 PM
mikeo0o0o0's Avatar
mikeo0o0o0
First, do you have dual tanks? If yes, be sure which tank you're running on.
Next, check all the soft lines in the system for cracks. Over time these lines will get hard and crack allowing the pump to suck air and lose it's prime.
Old Dec 9, 2012 | 06:57 PM
HIO Silver's Avatar
HIO Silver
'just a note if it is still has the electric pump installed... electric pumps are better pushing fuel rather than siphoning fuel. It should be mounted as close as possible to the fuel tank.
Also, loosen the fuel cap so allow the tank to breathe and the pump is actually creating a vacuum.
Lastly, change or take the fuel filter out of the equation... if it is right after the electric pump, make sure the direction of flow is correct.
Vellu
Dec 13, 2018 05:37 PM
lilernie
16
Dec 31, 2009 05:52 AM
ford4x4956
Sep 15, 2009 09:28 PM
wifes65
Jul 24, 2008 05:39 PM
scorpionmarine
Dec 9, 2006 09:43 AM
