Hes not looking to do anything special with it other then start using it as a truck again he wont even be towing anything more then likely
He got quoted 2500-2800 to rebuild the motor he has and thought that was kind of steep when there this crate motors on summit for less then 2k
Its edelbrock performer 289 and a Summit 4 barrel carb I forget which one 600cfm i think and hooker compettion headers they were parts that i had bought new but never ended using and we figured if hes gonna pull the motor mine as well slap them on
Check "Jasper" for a stock rebuild engine with warranty. Gas Engines | Jasper Remanufactured Engines
When I worked for the City, we used a couple of Jasper engines and transmissions on our fleet vehicles. Never had any issues with them. Their pricing was very good compared to doing the work via local machine shop and self-assembly.
The drawback seems to be that they don't sell directly to the public. So you would have to find one of the Jasper Installers and buy from them, probably with some markup, or have them do the work. I'm not sure if a self installation carries the same warranty. Maybe this factor makes Jasper a not so useful recommendation.
The thing with remanufactured motors is you often times do not know what you are getting. I personnally enjoy building my own motors. If you wanted to stick with the 5.0 then the explorer motor is your best bet. Personally I would go with a 351w as they make a better truck motor. If you can find a 94 or later long block it will be roller ready and you can more than likely get by with new bearings, seals, and a hone job. That would be the cheapest route and you would know what you have.
The "not knowing what I'd be getting" is the big problem with rebuilt crate motors, I've heard some pretty bad stories (from true engine builders) about what is allowed through those kinds of assembly lines, I personally wouldn't want to risk it to save a few/several hundred dollars simply because of the amount of work required to change am engine, it can really ruin your day.
Same here. But not everyone as the tools and skills to do that job themselves. If your going to do this kind of work you should have a set of internal and external micrometers to measure bearing clearances, an engine stand, quality torque wrench, ring compressor, piston pin press tool, cam bearing installer, valve spring compressor, seal drivers, etc. The list can be pretty long depending on how much of the work you do yourself.
So most of these tools wouldn't be used again by a guy who just has a single engine to work on. It would not be cost-effective to do the work yourself and buy the tools unless you do a few engines. Or you could take the block and heads to a machine shop and have them checked/measured (block decked cylinders, bored/honed, crank cut, pistons installed, etc.). But now you back to the concern about using an unknown shop (you "don't know what your getting") and if something does go wrong it's "finger pointing" between machine shop and assembler.
So buying a crate engine (long block) with a warranty is not a bad idea for some.
