PO720 Code
Old Jul 28, 2017 | 06:03 PM
incognito1970's Avatar
incognito1970
PO720 Code
2005 Excusrion V10 6.8L
Have the PO720 code
Replaced alternator it was bad when tested
Replaced OSS - the voltage on this when running varies in the 1.3 - 1.7 range.
What should the ohm voltage read?
What would you try next?
Old Jul 28, 2017 | 09:22 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
Check over everything electrical. While a 7.3, my 720 was spurred by a swollen battery on the tray side so it was out of side and not obvious.
There's a very slight possibility it's the APS, I don't know if y'all's gassers use one or have a standard TPS. If you DO have an APS, do NOT try to disassemble it. Trust me. If you want further discouragement, look up my thread of the pedal disassembly.
Electrical gremlins are usually the cause of random trans codes and behavior, and they suck. Bad coils can cause stuff for y'all, etc
Old Jul 28, 2017 | 11:45 PM
incognito1970
Thank you - we are looking no luck so far.
We have a new battery too.
Old Jul 29, 2017 | 12:05 AM
Krazee Matt
Veteran: Navy
https://www.ford-trucks.com/forums/1...ed-sensor.html
Should be of some help if you haven't been through it already
Old Jul 29, 2017 | 02:13 PM
incognito1970
Thank you!
I was hoping for some quick short tips for a miracle. Gremlins are really frustrating when you were supposed to leave on vacation and you can't go because your truck isn't running. So frustrating.
Onto the next steps of the Gremlin hunt and hoping we make greater progress today. Its getting worse on the the test drive not better!
miserableloser
Oct 6, 2012 07:17 PM
buddy-z
1983 - 2012 Ranger & B-Series
Mar 10, 2012 12:42 PM
BobsF350
May 23, 2010 09:17 PM
Skreamr
Sep 20, 2008 12:17 PM
jm ray
Feb 19, 2008 09:46 PM
