battery light is on
Old May 23, 2010 | 10:30 AM
BobsF350's Avatar
BobsF350
battery light is on
have a 603 code and i checked voltage at batteries running have 14ish on both and same from alternator.Have a voltage gauge that plugs into cig lighter that reads 12.2-12.6 volts.
i cleans connections no help
Old May 23, 2010 | 09:17 PM
gearloose1's Avatar
gearloose1
Something is causing voltage not to get to the right place if you are only seeing 12V at the cig lighter and getting the error code.
Do the diagnostics beginning with battery load test, then alternator output... and bad connections.. see link below.
