93 F150 4X4 5.0
93 F150 4X4 5.0
Two questions I have on my 93 truck. Question One, What sensor could be causing my truck to idle poorly shortly after start-up? I start the truck up and it runs good at first, then I drive a few miles and whenever I stop at a light or sign it tends to act like it wants to stall yet is doesn't stall. Once I've been driving a little while it idles fine at stops. Second Question, What could keep causing my light switch connection to keep melting enough that I have to replace the switch once a year or so? I can smell a melting smell every once in a while and then eventually I have to replace the light switch connection in my dash because it has melted enough to cause lights to not work properly? Any advice is helpful. I have a 96 F-150, 93 F-150, 86 F-250 6.9L and an 84 F-150.
I had the same issue in one of my other trucks a little while back... After the 3rd switch I talked to the dealer and they recommended changing the plug that connects to the light switch... I was skeptical, but did it anyway with a new switch, and haven't put another in it since.... Try getting a new plug along with the switch if yours is bad if not change the plug... Good luck... Not sure on your other issue
Clean it with sea foam and clean the throttle body while your in there. I use an old tooth brush to scrub all of the carbon off and suck a bottle of sea foam into the engine thru a vacuum hose stalling it out at the end. Let it sit about 1/2 hr then run it hard until the smoke stops. You may be impressed with how it runs after.
f250timmy
1999 to 2016 Super Duty
03-06-2018 11:58 AM
Jageesey1
12-23-2015 03:08 PM
