Question my order says "crew cab" on Cotus yet it says Double cab 3/4 on Etis? Anyone know why the difference. I hope the factory made the correct truck!
Mine is a 350 so no COTUS for it. After a couple of weeks checking the ETIS site it expanded to over 100 different options that my truck had and didn't have. That will really blow your mind! In the end it turned out to be exactly as I ordered.
Etis just gave me the long list on my build, and it says the same thing about double 3/4 doors even though I've ordered a CC. I think this is just the way it's listed.
Same here. Also said "less front fenders" and "less rear seat belts". Not sure what they're thinking
What trim is yours? Its possible it means you're not getting the Platinum version and inflatable seatbelts.
Don't read too much into Ford's code. I worked at a dealer that sold 18 wheeler trailers and when we got the order report it always read completely different than what was submitted, but it'd show up 100% correct.
It's all in how their system was coded. Do yourself a favor and don't poke around on those sites. It'll drive you mad since you don't know their programming system.
My ETIS report said the same thing. Received my truck yesterday and it was in fact a CC like I ordered.
woah! I literally jumped on here to say WTH is going on, because my Etis report finally showed an hour ago, and it also said double cab 3/4 door while the sticker sheet had crew cab
Your ETIS report will report about 100 different things in the next few days, at least mine did. Some things will be right and many things will be wrong! Like I said earlier, it blew my mind. But in the end the truck will be as ordered.
