Fuel Additives
Old Jul 27, 2017 | 11:03 AM
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
Fuel Additives
I can't believe there isn't a thread on this site that specifically discusses Fuel Additives.
I've read through the benefits of using them on both your ignition and emissions systems. Seems like something that should be used. The question is, which one is the "best".
So far I've narrowed it down to a few:
Diesel Kleen - seems to be a pretty good seller. I've seen a post I think in the 6.4 forum about someone that used it helping his regen cycle.
Stanadyne - This one seems to always be mentioned as one of the best
Liqui Moly - another one that is mentioned in a few places as one of the best
Royal Purple Max-Tane - Same deal - mentioned in a few places as one of the best
AR6200 - This seems to be a "compound" and I found 2 additives that contain it - Alliant Power Ultraguard and Archoil AR6200
The last one on at least my radar is Lucas fuel treatment
I haven't really figured out which one to go with. I'm guessing with like most of the other "stuff" any will "work". I need to find that "happy spot" in my brain so I'm not regretting my selection.
Wondering what everyone else is using if anything
Old Jul 27, 2017 | 11:43 AM
Big-Foot's Avatar
Big-Foot
Ask your dealer what you can use and if you would be in any danger of losing your warranty should you have a fuel system related problem.
Old Jul 27, 2017 | 12:51 PM
jonrjen's Avatar
jonrjen
There has been dozens of discussions on fuel additive here on the forum. It covers the plus the minus, the worries, the Warranty, and any other risk an owner could face.
One of the additives that you left off of your list is the Ford Motorcraft product sold in dealerships.
Over all I think that 6.7 owners are some of the more worried vehicle owners on the road. We all want to extend the life of our engine. But do so with out worries of any warranty claim being stricken down and being red flagged in the system.
Ford does like to keep us on our toes, that is for sure. Don't believe me check out all of the latest questions of CJ vs CK oil approval for use in the 6.7. Every oil manufacture out there says that the new CK oil is good for use in all CJ required vehicles. Yet, Ford says it ain't so. Now Ford does keep updating their Approved Oil List, but in the mean time do owners have to change their choice of motor oil to stay in the Ford Warranty Good Graces?
And to make it even more fun the oil manufactures have been reported as to filling the old CJ oil bottles with the new CK oil formula.
So in the end, if you want to use a fuel additive do your homework and make a choice. Make sure you understand exactly what the additive does if there is water found in your fuel.
Me, I stopped using an additive a long, long time ago. I make sure to stop and fuel at only well know fuel stops and drain my fuel separator bowl every three weeks or less. I have yet to find any water in my fuel. If you are adding it for lubrication or power, again make sure you know what is in the additive.
Some times I think we could have a new game show for prime time TV called "Ford 6.7 the Warranty Risk Factor".
Old Jul 27, 2017 | 01:04 PM
Olds64's Avatar
Olds64
I use the Lucas fuel treatment in my IDI. It's pretty reasonable on Amazon. Of course, the needs of an IDI are quite a bit different than the needs of a 6.7L PS. Definitely use something that won't void your warranty.
I don't know if I have the file anymore but I saw a study someone did on about a dozen or so different fuel additives. It was all done professionally and the results were quite surprising (meaning there wasn't much difference between the name brand additives). It might be worth a Google to see if you can find it. I will search my computer at home and see if I still have it.
Old Jul 27, 2017 | 01:05 PM
Nipperdog's Avatar
Nipperdog
You can use what ever, but I have been using Ford PM-22 for my last 3 Diesel Trucks and never had any issues with the Fuel System or Engine Performance.
Old Jul 27, 2017 | 01:57 PM
Olds64's Avatar
Olds64
Here is the file. It's from the Diesel Place, a GM site.
It's good info though. Maybe I should go to their site and make fun of them... nah. They're probably too busy trying to fix their Duramax.
Old Jul 27, 2017 | 01:58 PM
Turd-250's Avatar
Turd-250
sub'd!
10 character minimum
Old Jul 27, 2017 | 03:11 PM
Braggs's Avatar
Braggs
I've been using Opti-Lube Summer+ in my vehicle. This wasn't in your list.
Old Jul 27, 2017 | 03:43 PM
dirthawg's Avatar
dirthawg
I'm using PM-22 every tank for injector lubrication. I fill up at Diesel islands when possible or at stations that see a lot of business.
Old Jul 27, 2017 | 04:35 PM
Pocket's Avatar
Pocket
There's a mountain of threads on this subject. And many different "opinions".
The most important thing you should be considering when choosing a fuel additive is to consult the Ford Owner's Manual. It is VERY specific regarding fuel additives, and it's specific for a REASON.
Short and simple, the wrong additives can actually cause additional wear, can allow water to bypass the separator, or a host of other issues. Ford states in the owner's manual to use PM-22 (or PM-23 in the winter) or EQUIVALENT.
Additives that are formulated differently and/or advertise to do more than the Ford products should be avoided.
MSDS sheets are easily attainable online, making it simple to compare products side-by-side.
Old Jul 27, 2017 | 05:58 PM
SkiSmuggs's Avatar
SkiSmuggs
I also use Opti-Lube Summer Plus which is not on your list but was a top performer in the PDF posted earlier. Diesel Kleen is popular because it is available everywhere but was a poor performer in the previously mentioned PDF 2007 study. Any additive you use should not necessarily be a popularity contest winner. It is important to note that the 2007 study was for lubricity only so DK may be good for cetane boost, etc. I saw a comparison from a Lucas user who ended up switching to DK after testing with it. If there is any bio in your fuel, lubricity is probably not an issue.
Reason to use? Poor US fuel quality standards with a cetane minimum of 40 when Europe has specified 51 for years, keeping HPFP and injectors lubricated for long life and reducing soot to give your DPF and EGR a long life. BTW, Ford's PM-22 is made by another additive company, contains cetane booster, lubricity and detergents. Sound familiar?
Old Jul 27, 2017 | 07:26 PM
Readgriff's Avatar
Readgriff
Ski Smuggs
You state the Fords PM-22 is made by who?
Old Jul 27, 2017 | 07:45 PM
dirthawg's Avatar
dirthawg
Originally Posted by Readgriff
Ski Smuggs
I believe sta-bil is the manufacturer of PM-22.
Edit: Yep I remembered correctly. https://www.ford-trucks.com/forums/1...l#post15356899
Old Jul 27, 2017 | 07:51 PM
SkiSmuggs's Avatar
SkiSmuggs
Ski Smuggs
I don't remember, but it has been brought up in dozens of additive threads across several forums. It may very well be Sta-Bil.
The point is that Ford has a video suggesting that US diesel is variable enough that some doesn't even meet the minimal standards and that PM-22 is recommended to verify that our engines are getting enough cetane and lubricity.
While I haven't tried it (yet), Stanadyne Diesel Performance Enhancer would be the one that stands out in almost all discussions like this and can be had at many retailers. Since I ordered the Opti-Lube Summer Plus gallon jug with pump and spare bottles, I have little incentive to use anything else. I was tempted by Amalgamated TDS-FL as it seems to have produced great fleet results, but it looks like it takes twice the dose of my Summer Plus which makes me question the economy and convenience of it.
http://www.dieselfuellube.com/order2.html
http://www.amalgamatedinc.com/tdr-fl.aspx
Old Jul 28, 2017 | 06:37 AM
SkiSmuggs's Avatar
SkiSmuggs
