Effing frustrating gp system stuff
Old Jul 30, 2017 | 06:56 PM
Jon143's Avatar
Jon143
Originally Posted by tjc transport
no problem. we all have ot learn these things, and it is a lot easier learning from someone that has been htere than trying to learn on your own.
the easiest way is to climb up in the engine and put the test light or meter on the glow plug relay output terminal or to one of the glow plug tips. then have someone turn the key to run. if you see power with the WTS light on, when it turns off when the light goes out, the relay is working. you should also see a burst of power when the after glow clicks.
like i said, i hook a 12 volt LED to the output of the glow plug relay and mount it in the dash. this way i know for a fact when the plugs get power and when they do not.
I like the led idea then you know the relay is working and controller. So the led would only be on 10 seconds or the same time as glow plugs are on and it must flash when the afterglow works right lol I will use this. And after I check the relay I'll do same process to the harness because that is the only next thing. I'll post my reading and info soon
Old Jul 31, 2017 | 04:45 AM
tjc transport's Avatar
tjc transport
i ain't rite
yup, the led is only lit when power is going to the glow plugs.
Jon143
Apr 27, 2018 11:49 PM
Jon143
Jul 24, 2017 11:59 AM
bluemtn95ford
13
Oct 22, 2015 07:05 PM
EngNate
Dec 7, 2013 10:09 AM
WALJON
29
Mar 20, 2008 07:52 AM
