Request for Picture - Radiator Support
Old Jul 26, 2017 | 03:31 PM
reamer's Avatar
reamer
Every photo above are "AC core supports" Enclosed below are 4 photos of my core supports/radiators. First 2 show the NON AC core support that I repaired and installed, (before I got the AC equipped cab). Notice the "filled in area" circled in red. this core support supported the smaller (29" radiator that came with the non AC truck). Notice the opening is off center.
When I swapped cabs and took all the guts for the AC under the hood, I left the AC core support at the bone yard.
When installing the AC radiator and condenser, I found they would not fit, it was way to wide" in my rebuilt, original core support. Had to go back and pull the AC core support.
Non AC radiator is 29" wide. AC radiator and condenser are 34" wide.
Old Jul 26, 2017 | 03:42 PM
Gary Lewis's Avatar
Gary Lewis
Ron - What years were those trucks? As said, the catalog shows that the EOTZ 16138—A support, which had a smaller opening, was used for 1980 though '82, but it was not used after that. So, could your "non-A/C support" be that one.
Old Jul 26, 2017 | 03:46 PM
reamer's Avatar
reamer
Could be but the Stripped cab was a 1984....the AC was 1986......
Old Jul 26, 2017 | 04:51 PM
Gary Lewis's Avatar
Gary Lewis
Hmmm. Dunno. All I know is what I read in the catalog.
Old Jul 26, 2017 | 08:05 PM
reamer's Avatar
reamer
And we know the catalog is always right......
Old Jul 26, 2017 | 09:48 PM
Gary Lewis's Avatar
Gary Lewis
Not hardly! You should see the many corrections I've made in my catalog.
Old Jul 27, 2017 | 07:19 AM
FuzzFace2's Avatar
FuzzFace2
If I can remember I will check the 2 supports I have for size, etc.
Both should be 81's, 1 AC the other not.
Dave - - - -
Old Jul 27, 2017 | 10:03 PM
Gary Lewis's Avatar
Gary Lewis
Here's my 1982 support. The truck had a 351W and A/C w/a C6. And the opening for cool air on the left/driver's side has been cut out as I'll be using a dual-snorkel air cleaner. While there wasn't originally an opening there, there was a stamped spot where the opening would be.
Old Jan 5, 2018 | 10:47 PM
kr98664's Avatar
kr98664
For anybody who comes across this old thread, the results are here:
https://www.ford-trucks.com/forums/1...condenser.html
otnot
Oct 16, 2018 05:36 PM
xjpilot
Dec 10, 2013 08:06 AM
mrblonde108
Dec 28, 2011 11:20 PM
dennisb56
Mar 20, 2011 05:36 PM
Decoder01
17
Nov 5, 2010 08:21 AM
