Missing locking hub
Old Jul 24, 2017 | 07:36 PM
Kar555's Avatar
Kar555
Missing locking hub
I have an 87 F-150 with manual locking hubs. I recently had a tire fall off and the locking hub went right along with it into the woods where can't find it. I've had tons of trouble finding a replacement part. I wanted to know if i could still drive my truck in 2wd while I'm missing the manual locking hub.
Old Jul 24, 2017 | 09:35 PM
andym's Avatar
andym
You have the dreaded flange hubs. They were only used in one year. They are very hard to find parts for. If you plan on keeping the truck for a while, you're better off getting a Dana 44 from a junkyard and swapping it with what you have.
Old Jul 25, 2017 | 08:25 AM
tjc transport's Avatar
tjc transport
i ain't rite
good old "tophat" hublocks.
as Andy said, you would be better off looking for a F150 D44 with bolt on locking hubs.
it will probably be cheaper to replace the complete front axle than to find and buy one hublock.
Old Jul 25, 2017 | 08:43 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Nothing good about them. The stupid high shear nut isn't up to the task of the stress from the 35" tires. Last Summer, I grabbed a spindle off of a Bronco in the junkyard as a spare for my Bronco since don't think they are available anymore. I agree you'd be better off grabbing either a complete front axle assembly or just the axle shafts and spindles from the junkyard. As you may already know the auto hub version in '87 - early '88 used the regular style spindle and hub. Last time I saw them available was from JBG at almost $200?
Old Aug 12, 2017 | 07:41 AM
My4Fordtrucks
Did you locate another hub?
Old Oct 24, 2021 | 08:23 PM
Ginger Stearns's Avatar
Ginger Stearns
I think someone took my front passenger hub and replaced it with a damaged red one and it should be white
Old Oct 24, 2021 | 08:37 PM
Ginger Stearns
Is it possible some one took my hub
Old Oct 25, 2021 | 04:33 PM
My4Fordtrucks
The center dial that you turn is screwed on and can be easily swapped out in a couple minutes. On the other hand, in order to remove the “top hat” manual hub on an ‘87-88 1/2 you would have to remove the tire. It would be pretty obvious it they took the whole assembly. The OEM color from Warn was red. Their aftermarket replacements are black.
Markus Luukko
Jul 12, 2018 10:06 AM
Mumbly Joe
Sep 9, 2016 02:00 AM
icantdo55
Jul 19, 2010 07:31 AM
63' f100
17
Jun 15, 2010 12:35 PM
mudpig
Offroad & 4x4
Aug 7, 2001 01:54 AM
