So I did a dumb thing a year ago. I went to the local Ford garage to purchase my towing vehicle for retirement. I figured F-350 gas I should good, let them know what my interest was. Not one salesperson out of 4 said that you do realize the 5th wheel you want needs a dually. So now I have a 2016 F-350 XLT with 2900 miles to get rid of.
Now to sell mine and find a dually.
I found 2 used diesel duallys with around 67000 miles which I will probably trade on and just take the beating.
2011 F-450 4X4 King Ranch with 430 gears.
2012 F-350 4X4 XLT with 373 Gears.
I do think the 373's would get me about 5 mpg better.
You men towing with these set ups which way should I go?
Edited because I'm an idiot completely missed the part about you going diesel dulally. You should really post the specs of your trailer if you actually want some help. All the things you can do to your truck don't actually increase the capacity. Though they will make it tow better. I would skip the 2011 though as it was the first model year and there was the valve and glow plug issue which led to a 20k motor and there were also some trans issues but I think they were pretty much sorted out with flashes.
why not look into a dually rear axle and outer fenders. to your current truck.
but the bigger question.. WHY?? the need for a dually
What are the Issues ??? bigger front and rear anti-sway bars... rear air bags... there are things you can do with your current F 350..
as the single rear wheel F 350 is very capable .
how about the details of the 5th wheel trailer..
others will be along with more useful information.
With the newer, larger fifth wheels, it's very easy to exceed the load ratings on the rear tires. Our "mid-profile" fifth wheel scales at 3,100 lbs. on the pin. With a good hitch in the bed, we were too close to the load limit(s) on the load range E single rear tires... which is why we now have a DRW truck.
OP - our 2012 F350 Lariat LB CC 6.7 has the 3.73 rear end. Don't get the ratios used on gassers vs. diesels confused - completely different engines and torque profiles. The 6.7 DRW with the 3.73 rear end is a towing beast. We get 11 MPG overall towing 14,000 lbs. On the other hand, we don't buy big fifth wheels and diesel trucks and then worry about fuel economy. Just pick the right tool for the job.
We have only started looking at 5th wheel campers. We don't own one yet. We are looking at the 35'-40'. We want to be able to add an auxiliary fuel tank and generator in the truck bed. 5th wheel roof will have solar panels also. Washed, dryer, full size refrigerator and so on. We are really looking at the Montanas.
Plans are leaving for Alaska in June and spending time in various places until September, then heading south to warm weather. We figure on scouting around every year until we can't. 12751 dry weight is the one we are looking at right now, without the washing and drying. Pretty sure I'm maxed out at 12,300. Dry weight is 400 over that.
Maybe have to look at something different if I keep this truck
Look at Heartland, Grand design and some others as well. Keystone has really let their quality slip in the last few years and it's sad, because Montana was once at the top of the heap.
Just FYI.........a friends experience with Montana/Keystone
And just some more FYI......I pull my 41'Raptor, 18,000GVW all over the Rocky Mountain States with my '16 F350 DRW with 3.73 gears, 6.7L Powerstroke with absolutely NO trouble.......no need for deeper gearing.
that Link I passed to another shopper just yesterday..
I was a few weeks away from ordering a Montana 380 .. and decided to keep my OLD trailer. because of montana's treatment of the above owner..
I do not know any of the parties ..
First, there is not going to be a 5mpg difference among those gear choices.
Without knowing your 5th wheel specs, I would probably go with the 3.73 in general.
But if you are really getting up in weight and planning to climb long serious grades, then I would go for more gear.
This is all philosophy without the 5th wheel specifics.
Also, are you planning to full-time? Tow it a few weeks a year?
On Edit: I see a few posts happened between the time I started a reply and finally hit post.
i wouldn't be surprised if it's really close to a 5mpg difference. 10-11 with the 350 and 6-8 with the 450 are probable realistic numbers.
My 13 350 has 3.73 and it pulls everything I've hooked to hit just fine. Including my in laws 22,000lb loaded toy hauler. My Sundance is 15000 loaded and I have a 50gal six fuel tank in the bed, wife, 2 kids, 2 dogs all kinds of blocking, 150ft of 6-4 wire among other things and it pulls like they were made for each other. 11.5mpg on the flats and 9-10 in the hills.
