In the last 6 months I've had 3 heater cores go out in my 89 7.3 idi, The original and 2 aftermarket Spectra cores. I checked for electrolysis with a volt meter, showed 0.0.95-0.1 well below the 0.3 minimum. Its got a 7lb stant radiator cap, not sure what else to check. The last core blew and I found a pinhole in a tube.
I stopped having frequent heater core failures (6-9 months) when I stopped buying cheap China aluminum cores. Buy a brass Motorcraft heater core and it'll last a long time.
I just ordered a new motorcraft aluminum heater core, original aluminum one lasted 28 years. Gonna change the coolant and the additive(vc-8), is there anything else I should do? Thought about hooking a gauge up between the heater hoses and checking for excessive pressure.
^^^this^^^
the cheap china replacement cores are paper thin. get a made in USA core and it will last 30 years like the original did.
If your old core was aluminum it was not original. OE/Motorcraft heater cores have always been heavy brass/copper. As of a couple years ago they still were, it would be quite unfortunate if they stopped making them and sell rebadged China aluminum now.
From what all I see, 80-86 is brass,87+ is aluminum, it had Ford on it, I'll get a pic when I get home
Glad you figured it out, the brass cores are a heckuva lot better than the aluminum ones. One other thing that will help, is soldering a ground wire to the core and running that to chassis ground (firewall works well). It will help prevent damage from electrolysis. You can also add a radiator cap that has a sacrificial anode to help prevent it as well.
