Repeat heater core failures
Old Aug 21, 2017 | 06:29 AM
FordTruckfan89's Avatar
FordTruckfan89
Originally Posted by fordtruckman838
Glad you figured it out, the brass cores are a heckuva lot better than the aluminum ones. One other thing that will help, is soldering a ground wire to the core and running that to chassis ground (firewall works well). It will help prevent damage from electrolysis. You can also add a radiator cap that has a sacrificial anode to help prevent it as well.
I looked into the grounding, it actually in theory promotes electrolysis because besides the coolant, the core is isolated from metal. Ford had a tsb saying to do it, then had one superceding it saying not to. If this one goes it's getting a coolant flush,and a more thorough examination. Seems to be doing just fine so far.
Old Aug 24, 2017 | 06:36 PM
swhitney133's Avatar
swhitney133
Water no good use distilled water
When I flush or replace don't use household water way too many contaminants. Use distilled water if mixing your own 50/50 mix. I suggest a coolant filter if you have the money.
Old Aug 24, 2017 | 06:38 PM
swhitney133
Use distilled water if mixing pure antifreeze
Old Nov 5, 2017 | 08:04 PM
FordTruckfan89
The ford heater core kkjust barely made it into November. This one has some noticeable pitting around the fittings, I am 100% it is electrolysis, for right now, I bypassed the core, gonna drain it and refill with some fresh green coolant, distilled water and VC-8 additive. cleaned all the underhood grounds I could find, added a 4 gauge ground cable to the engine to frame connection and plan on adding some to the body to frame connection. Thinking of going with a ford Bronze heater core so it is a similar metal to the radiator, any input?
1974xlt
15
Mar 26, 2016 06:49 AM
RA31925
Mar 5, 2013 08:28 PM
dohc_chump
27
Sep 28, 2010 03:04 PM
Tazzmann
Oct 11, 2005 08:38 PM
