Radiator flush
Old Jul 24, 2017 | 12:29 PM
tcjhkbjt's Avatar
tcjhkbjt
Radiator flush
What is the easiest and cheapest way to flush out the radiator after an oil cooler change.
Old Jul 24, 2017 | 06:36 PM
hwybee22's Avatar
hwybee22
check the tech folder, there's a thread with step by step instructions.
69cj's Avatar
69cj
Flush repeatedly with straight water only. Removing the t-stat accelerates the process. You can start with hose water for the first 5 to 6 flushes and then do distilled for a couple. Finally drain, add 50% of capacity with concentrated coolant and then top off with distilled. Re-install the t-stat before that last refill. Do not use any chemicals as you take the chance of breaking crud loose and plugging the new oil cooler.
Old Jul 24, 2017 | 10:19 PM
white Buffalo's Avatar
white Buffalo
I was going to post the link to the PDF document in the Tech Folder (Powerstroke Cooling System Flush Overview and Flush PDF), but it seems the link is no longer valid. It was a great set of instructions with pics that helped me out alot when I did mine 2 years ago. Does anyone still have a copy of it?
waterboy_fishing
Apr 17, 2016 10:45 AM
happscrap
Nov 22, 2014 04:04 PM
miteldan
Nov 2, 2012 09:36 PM
daveya48187
Escape & Escape Hybrid
Mar 28, 2012 06:30 PM
Boba Fett
May 30, 2011 10:36 AM
