Parking Brake Automatic Adjust Madness
It does not have the "wedge" between the pawl and sector gear.
You may recall from other threads that my parking brake wasn't working well. When I had the drums off for replacement I found and fixed the reason why. I took photos and will do a post on this, time permitting. Basically, there were burrs and sharp edges that prevented the parking brake applicator from moving full travel.
Now the auto adjuster is not doing its job. The best that I can get is about one inch above the floor where I am essentially pushing with my toes. Here it holds better than before my repairs inside the drum. Other times the pedal goes all the way to the floor. If I could get it tight about 1/2 to 3/4 way down I know the parking brake will hold very well.
Here is what is going on. I put a punch mark on the part that holds the pawl and another one adjacent to it on the part that has the sector gear so I could see relative movement between the two parts.
Upon applying then releasing, the punch marks move showing tightening of the cable by one tooth where the pedal goes to one inch above. The next application and release the punch marks show loosening by two teeth where the pedal goes to the floor. The next application, release the punch marks are adjacent again. When it is at one inch there are 5 or 6 teeth on the sector gear that could be used to make it tighter. Note that before repairs inside the drum the pawl was in the third slot of there the sector gear.
All the manuals say is that the adjustment is automatic and no service is necessary.
Signed, At Wits End.
Success? Kinda. With the rope removed and the pedal released the auto adjust put it back to where it was in my original post. I know that they have those wedges that prevent the pawl from disengaging the sector gear and the auto adjust from working. I could get one of those, but it would be nice if it worked right.
Have you tested your parking brake this way? What were the results?
Bad news is the automatic parking brake adjuster failed and created enough drag to heat the brake drum to a deep purple (about 550 deg F). The drums are thoroughly warped.
I hope the shoes are OK. Any opinions on this?
Good news is I didn't like the Centric drums because they don't have the proper groove at the outer edge to form a labyrinth seal with the backing plate and this won't keep the water out like it should. I bought NOS Ford, made in the USA, drums on eBay for about the same price as the crappy made in China drums. I can't wait for them to get here. First delivery estimate was Friday, then today, now they are guessing Tuesday.
