Gas gauge help
Old Jul 22, 2017 | 04:44 PM
Lil' Marlene's Avatar
Lil' Marlene
Gas gauge help
ok as usual I feel like an idiot, it seems my 47 has been converted to twelve volt. I have NO gas gauge! There is about three inches of wire with what looks like a resistor hanging from the tanks sending unit where I guess it was cut....Do I just re run a wire from the send unit to the gas gauge and bobs your uncle? Or do I need two wires with a ground some where? Do I go to the battery then the gauge?
HELP? I need the easy simple version.
thanks guys😊
Old Jul 22, 2017 | 07:27 PM
Rust Wrangler's Avatar
Rust Wrangler
There is only one wire from the sender to the gauge. There is also a ground wire attached at the sender and the seat foundation. At the back of the fuel gauge there are two other wires connected opposite of the sender wire. One is a power wire that comes off of the ignition switch and another wire that feeds the oil pressure and temperature gauges. If running twelve volts you will need the resistor to lower the voltage to the fuel gauge in order to get an accurate reading. The resistor should be in series with the sender to gauge wire. Hope this makes sense.
Old Jul 22, 2017 | 07:29 PM
newold46's Avatar
newold46
Well, you could put a new sending unit in the tank and then rerun the wire to the gauge, or you could just run a wire and see what happens. Chances are good that your current sending unit has seen better days.
newblder
15
Jul 1, 2017 04:18 PM
NormH
Jul 24, 2012 03:23 AM
alvald83
Jul 23, 2012 08:32 AM
iwanaflattie
19
Dec 3, 2010 06:45 PM
gtex
18
Nov 4, 2002 04:46 AM
