Temp gauge not working? How do I check?
Old Jul 23, 2012 | 07:53 AM
alvald83's Avatar
alvald83
I just took my '69 truck and new '69 Tear Drop slide in camper on its maiden voyage and noticed that my temp gauge stayed on "C" the whole time.
It was in the 90's and I was hauling this 1200 lbs camper up and down hills and the needle didn't change.
Is there a good way to check my temp gauge or should I just replace the sending unit to start?
Old Jul 23, 2012 | 08:32 AM
elgemcdlf's Avatar
elgemcdlf
Unhook the wire from the sending unit. Find something to stick in the end of it to ground. With ignition on the gauge should peg out hot. If not your problem is in your gauge or wire running to it. If it does the problem is the sending unit. Let's say it didn't. The next move is to disconnect the wire from the gauge. Now with a ohm meter connect 1 lead to the sending unit side & 1 to the gauge side of the wire (not the gauge, the wire that connects to it). Did the ohm meter read 0? If so the wire is good. If not the wire is bad. Wire good the problem is with the gauge. Wire bad is obvious.
theGman
Jul 25, 2007 08:09 AM
Stoney57
Aerostar
Feb 10, 2007 01:08 AM
okacookie
1978 - 1996 Big Bronco
Feb 28, 2004 11:11 AM
jevanof
Electrical Systems/Wiring
20
Jan 13, 2003 08:11 AM
90EBBronco
May 8, 2002 07:00 PM
