anti-rattle bars
Old Jul 20, 2017 | 02:37 PM
markeyd's Avatar
markeyd
anti-rattle bars
Does anyone know if you need to remove the glass entirely from the door in order to replace the anti-rattle bars on a 1966 Ford F-100 custom cab, or can you do it with the window rolled down?
Was probably going to get them from Dennis Carpenter unless someone has a better recommendation. Thanks.
Old Jul 21, 2017 | 07:45 AM
aj64f100390-292's Avatar
aj64f100390-292
I will warn you that you have to look real hard for a kit that has the stainless lower side ati rattle strips that truly "fit" I looked at several online, and what I got from lmc-Vintque brand and they fit and work and all but they leave a nasty gap in the rear bottom corner where they meet the other anti rattle track/run. Now I've seen seen a slick at a car show that had the stainless kits that fit right...but he didn't remember where he got it....but if you don't care about whether its stainless I think the black kits fit better-just by the pictures as I've never had one in my hands to look at. I'm sure someone has more info of who has the best kits. I'm leaning towards a real rubber window sweep, sending my old ones to metro rubber or somebody who makes long lasting rubber and ask if they can make it have a sot for some stainless trim...
Old Jul 21, 2017 | 09:31 AM
Crop Duster's Avatar
Crop Duster
Try this link. Also DC has instructions in their catalog on replacing the anti rattlers and vent window seals. https://www.ford-trucks.com/forums/4...ows-parts.html
Old Jul 21, 2017 | 09:39 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
2) C1TZ-8121452-A .. Belt Weatherstrip aka Cat Whiskers aka Anti-Rattlers / Right Outside & Left Inside / Reproduced
2) C1TZ-8121453-A .. Belt Weatherstrip aka Cat Whiskers aka Anti-Rattlers / Right Inside & Left Outside / Reproduced
Old Jul 21, 2017 | 10:21 AM
markeyd's Avatar
markeyd
Thanks. Looks like door glass needs to be removed before anti-rattlers can be removed to make way for the new ones. If anyone disagrees then let me know. Thanks again.
Old Jul 21, 2017 | 10:35 AM
NumberDummy
You do not need to remove the glass. Not only is it unnecessary, but it's a PITA to R&R
Nylon window roller clips onto the stud of window regulator, then fits into the window channel that the glass is adhered to.
Remove the window roller from the window channel, drop the door glass w/channel down to the bottom of the door, install the anti-rattlers.
Old Jul 21, 2017 | 10:36 AM
markeyd's Avatar
markeyd
You do not have to remove the glass.
Remove the window roller from the stud of the window regulator, drop the door glass w/channel down to the bottom of the door, install the anti-rattlers.
Thank you.
Old Jul 21, 2017 | 11:01 AM
TA455HO's Avatar
TA455HO
Lead Gopher
The original anti-rattlers didn't have the stainless bead but were simply black. I think you can get the reproductions either way.
I'd love to find some of the C1TZ-8121453-A in NOS.
I only have some of the C1TZ-8121452-A so far.
Chad
Old Aug 8, 2017 | 09:37 AM
97_Stroke's Avatar
97_Stroke
my windows are already out due to going to body and paint, so doesn't matter. I'm liking all of the input on this, thanks a lot.
josht
15
Sep 20, 2018 09:17 PM
Lindemanlax
Jun 7, 2014 02:06 AM
SIXTFOR
May 28, 2014 11:05 AM
Desert Soldier
Aug 4, 2013 06:44 AM
KermitTheMudTruck
Jul 13, 2012 12:26 AM
