Factory alarm interface
Old Jul 19, 2017 | 02:34 PM
ssande's Avatar
ssande
I have an old alarm setup I made for my previous truck for monitoring our ATV’s and trailer that I would like to adapt to my new F250. It was basically a relay wired into the door switch and used a long piece of CATV cable that was looped through everything and each end of the cable plugged into the unit inside the truck. The continuity of the loop of CATV cable kept a relay closed. If the cable was removed or cut the relay would release and complete a ground circuit which would simulate an open door and set off the factory truck alarm giving warning.
Does anyone know any triggers or inputs I could use on the factory alarm to reuse this interface? It’s simple and effective so I would like to reuse it if possible.
Thanks,
Scott
Old Jul 19, 2017 | 03:16 PM
Faceplant409's Avatar
Faceplant409
I need to do the same thing except I want to add a pin or mag switch in my tool box.
I found that there is a hood monitor switch on Lariat and above trucks. I suspect we just need to figure out if it is NO or NC and wire accordingly.
I wont have time to play with it for a few weeks, but if you do- please let us know how it goes.
Hooie2013
Jul 3, 2013 08:01 PM
4tl8ford
Jul 14, 2008 04:11 PM
BigJim191
Mar 26, 2007 12:38 PM
stupato
1978 - 1996 Big Bronco
Jan 29, 2005 10:46 PM
Tomc750
Dec 13, 2001 07:08 PM
