Tri-Max tow hitches
Old Jul 17, 2017 | 01:17 PM
PwerStroke99's Avatar
PwerStroke99
Tri-Max tow hitches
Anyone have any experience with these tow hitches?
Trimax Adjustable Tow Hitches | Titan Truck
Old Jul 17, 2017 | 02:34 PM
EpicCowlick's Avatar
EpicCowlick
I have one and use it as a loaner now that I have a Weigh Safe. It worked fine for the most part but I was always a bit suspicious as to it's real strength. I never put more than a 7,000 or 8,000 lb load on it but it bent a little early on and I had to separate the base from the vertical shank with a sledge hammer. I had to remove a little bit of aluminum from base portion with a rasp so it wouldn't get stuck. I went from the Tri-Max to an Andersen Rapid Hitch which was great but had trouble with the underside ball on that hitch contacting the road a few times. I never questioned the strength of the Andersen but gave it away when I got the Weigh Safe.
Old Jul 17, 2017 | 02:39 PM
PwerStroke99
Good input, thanks. I am always suspicious of the hitches with substantial drop to them. I don't tow all that often, so just looking at options. Hauling a camper trailer over to Montana next month, and I think I only have a 2" ball, so was looking at options at having the dual ball hitch.
Old Jul 19, 2017 | 04:14 PM
Faceplant409's Avatar
Faceplant409
These definitely look like the nicest of the adjustable.
Im not sure I'd tow anything more than 5-6k with aluminum tho. ESP with a lot of drop.
Coming from a guy that has spent a small fortune over the years on ***** and ball mounts....
hydrophish
All Things Towing
Jun 7, 2019 02:28 PM
Neil64
6.4L Power Stroke Diesel
Nov 24, 2010 10:52 AM
Sgt93
All Things Towing
Oct 24, 2010 04:52 PM
LSUtigers
1997 - 2003 F150
16
Sep 10, 2006 09:39 PM
Oval_obsessed
All Things Towing
May 16, 2005 09:33 PM
