E150 trans identification
Old Jul 18, 2017 | 05:21 PM
Goldie04's Avatar
Goldie04
I have a 2004 van, with a 4 speed, overdrive transmission. I have searched this and other Ford forums, with no definitive answer.
I am attaching pics of the trans tag.
I have seen many "opinions" about this, so please no guessing, first hand knowledge only.
thanks
Old Jul 18, 2017 | 09:51 PM
annaleigh's Avatar
annaleigh
What are you trying to find out?
Half way down on page 90 is your transmission model.
2004 Econoline 5.4L 4R70W 4C2P-7000-BA; PKF-DL
Ford rebuilt part nubmer 4C2Z-7000-BARM
https://www.fordparts.com/FileUpload...06.09.2015.pdf
Mark Kovalsky is our Former Ford Automatic Transmission Engineer 1988 - 2007
And NumberDummy is our
Retired Ford Parts Manager
Dont know if you can PM them with made just one post..
Old Jul 18, 2017 | 10:10 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I don't have a decoder for the tag. If I knew what engine it had I could tell you what transmission it has. Or if I knew how many pan bolts I could tell which transmission it is. But I never learned how to decode the trans tag.
Old Jul 18, 2017 | 10:52 PM
Goldie04's Avatar
Goldie04
E150 trans ID
Mark,
It is a 5.4l gasoline engine.
If you look at the post above you, annaleigh tagged it from a FORD remanufactured transmission list.
thanks to both of you for your help and quick comments.
The next question is about using Mobil 1 synthetic ATF in this trans. Is the torque converter drainable on this trans?
Goldie04
Previous E150s: '78 with 320,000 miles-sold it running(300 six)
'95 with 211,000 miles-something in the motor broke
Old Jul 18, 2017 | 11:16 PM
Sam I Am's Avatar
Sam I Am
thanks
If you enter the vehicle's VIN in the site link below it will show you what equipment Ford put into it at the factory. Go to "vehicle" tab in the black stripe and enter your VIN in the box.
Vehicle Lookup
Old Jul 19, 2017 | 08:03 AM
Mark Kovalsky
From the factory there was no drain plug in the torque converter. I don't know if a remanufactured converter would have one or not.
You can do a fluid exchange on this trans which will change about 95% of the fluid. Here is how to do it with a 4R100, the 4R70W is similar:
https://www.ford-trucks.com/articles...-transmission/
Old Jul 19, 2017 | 09:48 AM
Goldie04's Avatar
Goldie04
Mark,
What about changing to Mobil 1 ATF in the 4R75W 4 Spd Automatic Transmission?
Old Jul 19, 2017 | 02:10 PM
Mark Kovalsky
That's a good choice. I recommend Mobil 1 Synthetic ATF.
Old Jul 20, 2017 | 12:03 AM
Sam I Am's Avatar
Sam I Am
"Mobil 1 Synthetic ATF meets or exceeds the requirements of Ford MERCON® V"
found here:
https://mobiloil.com/en/automatic-tr.../synthetic-atf
gyrocopter1
Jul 28, 2012 11:53 PM
carpentrymanok
Oct 6, 2010 06:06 PM
wmiller
Feb 16, 2009 03:07 PM
ClatonK
Sep 7, 2005 11:09 PM
