Sponsored by: Auxito
Front brake question
Old Jul 18, 2017 | 01:14 PM
1999-F150's Avatar
1999-F150
Simple question. I know on some cars and trucks you need a special tools to push the caliper back in. i just use a large c clamp to do the job. Question do i need any special tools to replace the front brakes pads?
Old Jul 18, 2017 | 03:16 PM
GadgetGuy22's Avatar
GadgetGuy22
I did not on my 98.
I'm think the ones that need a special tool are usually on the rear of vehicles.
Old Jul 18, 2017 | 04:07 PM
steve(ill)'s Avatar
steve(ill)
I have always used a c-clamp
Old Jul 18, 2017 | 04:18 PM
Chad T. Keogh's Avatar
Chad T. Keogh
I used a c-clamp to do mine last fall. No problems.
Chad
Old Jul 18, 2017 | 04:37 PM
1999-F150's Avatar
1999-F150
Sweet thanks guys!
Old Jul 18, 2017 | 09:00 PM
blackbronco92's Avatar
blackbronco92
C-clamp should work just fine. No special tools required to change out pads on the front. Just remove the two caliper slide bolts which hold the caliper to the bracket, use a rubber mallet to tap the caliper and it should slide off of the old pads. Hang the caliper to avoid putting stress on the brake hose. Pull the old pads out, install your new shims, and pop the new pads into the bracket.
Most important step here is if you have dual pistons in the caliper, you want to push them in evenly together. Use a small block of wood to distribute the pressure from the C-Clamp. Alternatively, I often use the old pad to push the pistons in together.
Old Jul 21, 2017 | 02:01 AM
steve2003's Avatar
steve2003
i second this. Used old pad and c clamp a couple months ago.
Old Jul 21, 2017 | 02:54 PM
Shadow351's Avatar
Shadow351
I suspect the special tools are for rear calipers with built in parking brakes, you have to rotate the piston as you compress it. My old Mercury had those and they were a PITA to compress, it ended up being easier to just replace them.
fatdan460
Offroad & 4x4
May 12, 2011 07:48 AM
psu152
Aug 19, 2008 05:13 PM
AG8FORD
Oct 28, 2006 12:00 PM
jcsv99
2004 - 2008 F150
Oct 5, 2006 03:38 PM
