Shifting Hasatation
Old Jul 22, 2017 | 05:19 PM
PupnDuck's Avatar
PupnDuck
Originally Posted by JKBrad
I had no idea the transmission fluid got thinner. That makes it essentially a 10w equivalent. I'm sure Ford/GM know what they're doing. However, here is South Texas, that would concern me.
Why? They spent over a billion dollars developing this transmission. Its designed to work with the fluid specified for it. The 10 speed uses a fluid that about equivalent to 10W. The 6 speed uses a fluid that's about equivalent to 20W.
Every transmission is designed to operate properly within a specified internal temperature range. That's the purpose of transmission coolers. Doesn't matter what transmission you have or what weight fluid it uses, if you overheat it, it will die.
The 3.5 EB calls for 5W-30 for operation in temperatures from -20 to 100+. The only exception Ford makes is to use 0W-30 if the temperature regularly gets below -22. The engine is designed for it. My wife's Honda calls for 0W-20 regardless of temperature.
Ford sells these things in parts of the world where a July day in south Texas is like a winter day.
Old Jul 23, 2017 | 08:41 AM
F350 1990's Avatar
F350 1990
The problems at the dealerships with tech crews are many and consumers see (and feel) the results:
-- Technicians have become too reliant on IDS
-- The Ford FACT schools and follow-on training standards have declined over time
-- Technicians are not happy with current pay scales
-- The older techs aren't thrilled with the "electronics" content in newer vehicles (now approaching 40% in some cases) and most, if not all of the, "original thinkers" (Master Techs, experts) see Ford relegating them to button-pushing IDS'rs, too reliant on computerized diagnostics vice their disciplined "components-level" troubleshooting/analysis.
I'm sure I'll get a Tech or two (or dealership reps on this forum) will chime in / claim otherwise, but they're the exceptions ..........
Old Jul 23, 2017 | 10:58 AM
The Big Tow's Avatar
The Big Tow
Originally Posted by CR172
Never noticed any hesitation on mine. Just sayin'. Hoping one can still get the 6 speed when I get the retirement truck. Along with the 5.0L.
The 5R110 was actually a 6 speed. Once warmed up, it stopped using 4th gear.
It's not unusual for automatic transmissions to have built-in safety features for cold weather operation
Ford 5R110W TorqShift Transmission Specs & Ratios
The 6R80 has cold weather operation protections as well. I'm sure the 10R80 does, too.
Not saying that's the problem the OP is having. Not this time of year anyway.
Old Jul 24, 2017 | 06:53 PM
KJ Smith's Avatar
KJ Smith
Originally Posted by AbitaPro
What are all the advantages of the 10 speed transmission, that you mentioned? Thanks
From what I can tell, far better city mileage.
Old Jul 28, 2017 | 09:06 PM
TJReams's Avatar
TJReams
All oil getts "thinner" as it heats. actually it just flows better. Multi viscosity oil does as well but it has additives that make it behave like a heavier oil, the oil itself is the low number on the bottle.
Old Aug 1, 2017 | 06:58 AM
excaliber551's Avatar
excaliber551
There are lots of reported issues with the new 10 speed transmissions on every forum. Take it in.
screwy
6.7L Power Stroke Diesel
Apr 22, 2023 02:14 PM
BCM
Jan 31, 2017 06:49 PM
djousma
21
Dec 21, 2016 12:35 PM
Dirtysnow
2009 - 2014 F150
Mar 23, 2012 07:10 AM
Wagion
Feb 24, 2011 05:10 AM
