Shifting Hasatation
Old Jul 18, 2017 | 10:33 AM
coonman111's Avatar
coonman111
Shifting Hasatation
I have a 2017 F150 XLT 3.5 Eco 10 sp has anyone hade a problem with there truck shifting when it is cold it will hastate when it shifts, completely slow right down.
Old Jul 19, 2017 | 06:08 AM
sb1988's Avatar
sb1988
I have the same exact problem. Mine lags somewhere around 3rd or 4th gear and does it the first shift of the morning every morning. After that...no issues.
Old Jul 19, 2017 | 09:05 AM
Kingofwylietx's Avatar
Kingofwylietx
Just a guess here, but it sounds like it isn't as efficient until it comes up to a certain temperature. I don't know if I'd consider that a problem or just a characteristic.
I have the 3.5EB and 10 speed. I haven't noticed this hesitation, but I pull out of my driveway and make an immediate turn, then another immediate turn as I go onto another street...it's probably doing that shift as I turn..so it's imperceptible to me.
If you get it checked out, let us know what they say. Or, someone more helpful on here might know what causes it.
Old Jul 19, 2017 | 11:31 AM
PupnDuck's Avatar
PupnDuck
I got my '17 Lariat in early January so I lived with this problem all winter. On a cold engine the normal mode shift from 1st to 3rd bogs a cold engine. Also, to a lesser extent the normal mode shift from 3rd to 5th.
Apparently this is just something you'll need to live with in the name of decreased fuel consumption.
You do have a couple of choices:
Let the engine warm up wasting time and fuel.
Be more aggressive with your right foot from dead stop. This makes it less noticeable.
Put it in Sport mode for the first couple of minutes until the engine warms up a little. This way the trans uses 2nd and 4th.
Just live with it. That's what I've come to do.
You would think that since everything from the engine to the interior lights are controlled by a computer that Ford could have programmed the transmission not to skip gears until the engine warmed up a bit but I'm willing to bet that this is the only way they can meet EPA emissions standards with a cold engine.
Old Jul 19, 2017 | 11:33 AM
pikapp's Avatar
pikapp
Mine lags going from reverse to drive, about a 2 sec. lag. Dealer says its normal. Same when I come to a stop sign and slowly turn without coming to a complete stop , it takes a moment for the trans to down shift. Go in for another oil change in a few weeks, will discuss again with dealer.
Old Jul 19, 2017 | 12:04 PM
coonman111's Avatar
coonman111
Have any of you talked to a dealer about it?
Old Jul 19, 2017 | 08:59 PM
GABAR's Avatar
GABAR
Does it do this if you let the engine idle down after you start it and which by that time, all of the transmission and engine fluids should be flowing well and warming up.
Or, do you just start it up, put the transmission in drive, and go.
Old Jul 20, 2017 | 05:31 AM
coonman111's Avatar
coonman111
No it idles for a few seconds then I get to the top of the hill and stop then I go and that is when it does it.
Old Jul 21, 2017 | 10:53 AM
The Big Tow's Avatar
The Big Tow
Even the 6R80's do that when they're cold. Once they get up to temp, they straighten out.
And it doesn't have to be below freezing or anything like that. Just cold-cold. Around 45 degrees for an extended period.
OTOH, it might be something else. Can't tell from here.
Don't force it, let the computer do its job
Old Jul 21, 2017 | 11:55 AM
coonman111's Avatar
coonman111
It does it when it is 87 out side.
Old Jul 21, 2017 | 12:09 PM
CR172's Avatar
CR172
Never noticed any hesitation on mine. Just sayin'. Hoping one can still get the 6 speed when I get the retirement truck. Along with the 5.0L.
Old Jul 21, 2017 | 08:34 PM
PupnDuck's Avatar
PupnDuck
Its really not a big deal. A little burp between 1st and 3rd maybe once or twice on a cold engine in exchange for all the advantages of the 10 speed. Don't turn a little glitch into an "Oh My god, I can't drive this thing" big deal.
Old Jul 22, 2017 | 12:45 AM
AbitaPro's Avatar
AbitaPro
What are all the advantages of the 10 speed transmission, that you mentioned? Thanks
Old Jul 22, 2017 | 11:47 AM
PupnDuck's Avatar
PupnDuck
Well, the 10 speed has the top three gears as overdrive whereas the 6 speed only has the top 2 gears as overdrive.
The 10 speed has a true direct (1:1) 7th gear, the 6 speed's top non-overdrive 4th gear is an under drive 1.14:1.
First gear in the 6 speed is 4.17 while in the 10 speed its 4.69. Not a tremendous deal but it might allow you to get away with a higher rear axle.
The 10 speed uses an ultra low viscosity fluid that is half the viscosity of the fluid used in the 6 speed. This reduces pumping and friction losses.
The more closely spaced ratios of the 10 speed do a better job of keeping the engine in its power band giving better performance.
None of these features are anything great when viewed alone but when taken together they do add up to reduced fuel consumption and less heat generated.
It seems that the automotive industry on the whole is going to 8, 9, and 10 speed transmissions behind smaller turbocharged and supercharged engines for performance and fuel economy reasons.
Ford may still have a few kinks to work out in the control software for their 10 speed but based solely on my experience over the last 6 months it seems to work fairly well.
Old Jul 22, 2017 | 03:09 PM
JKBrad's Avatar
JKBrad
I had no idea the transmission fluid got thinner. That makes it essentially a 10w equivalent. I'm sure Ford/GM know what they're doing. However, here is South Texas, that would concern me.
