Coolant temperature sensor resistance values
Old Jul 18, 2017 | 09:15 AM
MintFord's Avatar
MintFord
I've searched everywhere and I get different answers everywhere I look. Can someone tell me the correct coolant temperature vs. resistance values for the gauge sensor on a 1972 F250? Thanks!
Old Jul 18, 2017 | 12:20 PM
smoky_diesel's Avatar
smoky_diesel
I measure mine at 2 points:
26 ohms at 219F
315 ohms at 75F
https://www.ford-trucks.com/forums/1...l#post16654949
Old Jul 18, 2017 | 02:17 PM
MintFord's Avatar
MintFord
Thanks Smoky Diesel. I can't get my gauge to move off of cold at all. Cooling system is ok, no air pockets, etc. Gauge maxes out when I ground the sender wire as it should. I tried a sender from another car that I know worked, didn't help. I ohmed out both senders, plus a new one for a '72 and they check good, 275 ohms at 80 degrees down to around 20 ohms in a cup of hot water. I even ran an auxiliary ground to it while it was in the truck. I see that 1970 and newer take an identical looking, but different part number sender than '69 and back. odd considering the clusters look the same from 67-72. I wonder if my cluster is from an older truck that operates at a lower resistance.
Old Jul 18, 2017 | 02:43 PM
smoky_diesel
What is the voltage on the sending unit, when it is all hooked up? You should see it bounce around between 3-7 volts. If not check wiring.
SailBoatBuilder
Sep 26, 2017 09:43 PM
lhud
Computer Chips & Tuners
Oct 8, 2012 03:45 PM
WVRanger
1983 - 2012 Ranger & B-Series
37
Dec 1, 2004 12:14 PM
Tony3
Apr 16, 2004 12:49 PM
NVETHIS
Bronco II
Jan 22, 2004 07:30 PM
