Bronco II Ford Bronco II
coolant guage
Old Jan 22, 2004 | 10:28 AM
NVETHIS's Avatar
NVETHIS
coolant guage
My coolant gage in my '87 bronco does not work. Can this be the guage or the sender? Is there a good way to tell which it is? Thanks.
-Bryan
Old Jan 22, 2004 | 12:55 PM
Ken00's Avatar
Ken00
I bet its the sender. If you pull the connect of you will get cold and if you ground it you get hot, or is it the other way around, either way you'll find out if the gauge works.
Old Jan 22, 2004 | 07:30 PM
87 XLT's Avatar
87 XLT
Yeah, if you remove the connector from the sensor & shove a nail in it & then ground it beside the sensor the gauge should go to full hot.
