Starter button wiring ?.
Old 07-17-2017, 08:27 AM
the gruffalo's Avatar
the gruffalo
the gruffalo is offline
Hi ford folks, can anyone help me to workout how to wire up the starter push button on my 1952 ford f1. The truck must of had the ignition switch replaced at some time, as the switch that is fitted has four posts and the original switch only had three posts. I can wire the switch so that the truck will start with the ignition key , but I cannot find out how to make it start with the ignition switch turned on and pushing the starter button. The starter button has two wires coming of it, where do these connect to make it work ?.
Many thanks.
The Gruffalo
Old 07-17-2017, 08:48 AM
moejr's Avatar
moejr
moejr is online now
Received 1,020 Likes on 481 Posts
one wire is from the ignition switch "on" and the other wire go's to the start soleniod on the firewall.
Old 07-17-2017, 08:52 AM
the gruffalo
Thanks for the reply, the wire from the button to the ignition switch is it connected to the acc post?
Mick
Old 07-17-2017, 09:03 AM
Kurt G.'s Avatar
Kurt G.
Kurt G. is offline
Should be the one for run only not Acc, otherwise the starter could be engaged when in accessory
Old 07-17-2017, 09:12 AM
the gruffalo
Okay thanks for your help.
Mick
Old 07-17-2017, 10:07 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
The original Ford wiring has the starter button Hot all the time. "May" be a safety concern. It can be fed right off the 15 amp circuit breaker right next to the button.
Old 07-17-2017, 10:15 AM
the gruffalo
Thanks for the info on the circuit breaker. Can either of the two wires be used for the power and the solinoid ?
Mick
Old 07-17-2017, 10:28 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Mick
Yes.
If you have kids, Kurt's warning is worth thinking about. Kids love to push buttons!
Old 07-17-2017, 10:33 AM
the gruffalo
Thanks for the reply. Will have a look at it over the weekend. Will post update.
Mick
Old 01-08-2022, 10:46 AM
GEJ's Avatar
GEJ
GEJ is offline
the key switch on start mode is hot all the time also. So even if the engine is running and you turn the switch from run to start, the starter will engage. Same thing if you push the button while it is running.
Old 01-08-2022, 12:57 PM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
In simplest of terms, you want to cut the "ST" (starter) wire from the existing 4-position switch and connect it to one side of the new start pushbutton. The other side of the start pushbutton gets connected to "battery". Since I don't know whether you have 6v/12v or +/- ground system, I have left the markings on this generic diagram as is.
The following 2 users liked this post by CharlieLed:
Old 01-08-2022, 07:38 PM
ZSK's Avatar
ZSK
ZSK is offline
The above diagram will work in the simplest form. Alternatively, this setup requires the key to be on in order for the Push Button to work.
rollinblacksmoke
12-23-2013 06:11 AM
Woodsman_30350
06-06-2011 12:27 PM
wideopen23
12-24-2005 06:58 PM
53Trucker
09-26-2005 10:03 PM
77fromheaven
Electrical Systems/Wiring
05-02-2002 01:49 PM
Quick Reply: Starter button wiring ?.
