Throttle cable...
Old Sep 6, 2003 | 03:04 AM
FordToughF150's Avatar
FordToughF150
Question Throttle cable...
Hey guys, sorry if this topic has been discussed before. I tried a search first and didn't come up with much help. Probably because the search searches for throttle AND cable, seperately.
Anyway, I need some help with putting on my new throttle cable. Just looking for info on what's involved, I guess. I looked through my Haynes manual and found nothing.
Truck is in my sig, '80 F150 with a 302.
Thanks in advance
Old Sep 6, 2003 | 05:42 AM
Pkupman82's Avatar
Pkupman82
Throttle cable...
Easy, find the accelerator cable and follow it to where it goes in to the firewall. There should be 2 small bolts holding it in, remove them. The end that hooks to the carburetor/throttle body should just pull off, also there will be a bracket that holds the cable it's bolted to the intake. I am not sure about 302s but my 300 the cable just pops out of the bracket. Next you will have to go inside the truck under the dash the cable hooks at the top of the accelerator pedal arm, just pull it back and up and it should pop right out. Just repeat the same process for installing the new cable.
Old Sep 8, 2003 | 02:25 PM
FordToughF150
Throttle cable...
Thanks for the help. I figured it was pretty easy, and it is. I got the old one off, and the new one on...but the new one is too long! The spring had to be compressed to fit in, and that let the pedal down too far on the floor. Guess I'll just take it back and see if I can find a right one somewhere else.
Old Sep 9, 2003 | 02:05 AM
Pkupman82's Avatar
Pkupman82
Throttle cable...
That happened to me a couple times. Partially my fault partially the incompetant idiot working behind the counter at autozone. I shoulda brought my cable in!
Old Sep 9, 2003 | 05:00 PM
bremen242's Avatar
bremen242
Throttle cable...
You probably got a 300-6 throttle cable, they are a good bit longer, and as you noted, a pain to fit right. you prolly need to go get the other one
Old Sep 12, 2003 | 10:52 PM
Pkupman82's Avatar
Pkupman82
Throttle cable...
Well actually I just went across the street to Advance Auto Parts and got the right one the first time. No problems since!
Old Sep 13, 2003 | 11:29 PM
martianman24's Avatar
martianman24
Throttle cable...
I just Replaced the throttle cable in my 80' Ford F150 but mine was a 351 modified but highly doubt there is any difference between them the only hard part is a plastic insert that is hooked into the accelerator pedal be careful cuz some of these pieces (depends on parts store) are very brittle. other than that nothing difficult about it. if you are wanting a little more "pedal" stack some washers on the mount.
Old Sep 14, 2003 | 02:00 AM
Pkupman82's Avatar
Pkupman82
Throttle cable...
That's not a bad idea! I might try that.
SwOkcOffRoader
13
Nov 20, 2016 08:58 AM
bl2009
1997 - 2003 F150
Apr 16, 2016 07:08 PM
eatont9999
24
Aug 20, 2011 01:07 PM
Rothschild
Jun 7, 2010 11:34 PM
'86_150
Aug 26, 2007 04:48 PM
