From my experience, adjusting that cable can cause problems. On a 90 F150 I had with a 302, I adjusted the cable to get a higher idle speed. This in turn caused a very rough shifting condition with the transmission. There is some interrelation there. When I adjusted the cable back to the original setting. The transmission returned to the normal smooth shifting it had done before I "tried to fix something that was not broken".
