Transfer case shifter loose '77 F150 4x4
#31
#32
The following users liked this post:
#33
#34
#35
#36
#37
#38
#39
#40
#41
Hello everyone,
I am back with an update on my truck shift rattling; well, yesterday I received the new part, "New Process 435 transmission shift lever retaining cap" but unfortunately, the issue continues.
I was talking to a local mechanic and he thinks that maybe is the transmission synchronize.
I have to continue looking into it. Or what do you guys think may cause the issue?
#42
When "stuff" gets worn or worn out, parts that are suppose to go together with some tightness tend to get loose over time and miles and you get a rattle. When the syncros get worn it can make for a hard time to row thru the gears. Something is worn in there, for sure. Does it bother you enough to warrant a trans rebuild. Maybe the rattle is not that bad now. Turn up the radio.
Did you get a new spring in the kit? Lower left part in pics is a spring.
Board trick.
Board trick.
#43
Hi 77&79F250
Thank you for your advice. No, I just found NOS part on eBay and bought it, but now that you show a picture with all the components, I will buy one from https://www.novak-adapt.com/knowledg.../manual/np435/ they offer on their website.
To answer your question regarding the noise, the noise is not that terrible, but when I was reading the original post, I understood that it was something easy to fix with a bushing. I love my truck, and I would like to keep it in “good” condition, I haven’t done the engine support, and always is there something to work on it.
You have been so helpful.
#44
Pigpendirtface08
03-20-2019 10:58 PM
bjesdale
11-22-2005 01:44 PM
pihlboy
06-14-2005 02:21 PM
bcboy4ca
06-15-2004 04:17 PM
