tcase
Old Mar 26, 2006 | 09:32 PM
DMAN's Avatar
DMAN
tcase
does anyone know if the old cast iron tcase adapters will fit the newer case in my 84? the adapter is off a 205.
Old Mar 27, 2006 | 06:13 PM
thesprocket26's Avatar
thesprocket26
What case is in your 84?
Old Mar 27, 2006 | 06:45 PM
Briansshop's Avatar
Briansshop
I'm pretty sure all ford t-cases use the same bolt pattern & spline count. I know for sure that the BW 1356 & the NP 205 are the same.
Brian
Old Mar 27, 2006 | 08:23 PM
RTM's Avatar
RTM
In 84 it should have a 208 case. yes all of the full size trucks share the same t-case bolt pattern but the 205 case on a newer style, 80 and up adapther requires one to notch the newer adaper for the t-case shifter arm/rail to clear.
I have a 205 behind a Zf 5-speed and I had to make a notch and shorten the rod from the stock 205 shifter to the case and it shifts great.
