1978 - 1996 Big Bronco
driveshaft bolts
Old Sep 5, 2003 | 10:32 PM
joebronco94's Avatar
joebronco94
driveshaft bolts
I want to remove the driveshaft from the companion flange to grease the slip yoke assy.But the bolts look a little diff. has more than 8 sides on the bolt. waz up
Old Sep 6, 2003 | 12:23 AM
DW2455's Avatar
DW2455
driveshaft bolts
its probaly a 12point bolt head, use a 12 point socket or try a box end wrench. DW
Old Sep 6, 2003 | 01:36 AM
frogger01's Avatar
frogger01
driveshaft bolts
12 mil 12 point socket
Old Sep 6, 2003 | 08:27 PM
joebronco94
driveshaft bolts
thanks guys .
Old Oct 3, 2003 | 09:04 PM
maa139's Avatar
maa139
Same bolts on a 94 explorer. Anyone have any hints as to breaking them lose? I've only soaked them in wd-40 up to now. I'm a little leary of going under the truck with a propane torch, and haven't found any pb blaster. I've read that some people have used brake fluid or ATF fluid.
Thanks
Matt
Old Oct 3, 2003 | 09:10 PM
Roscoe1818's Avatar
Roscoe1818
50% brake fluid, 50% ATF. Havent tried the stuff, but i hear it works wonders.
Old Oct 3, 2003 | 09:14 PM
maa139's Avatar
maa139
I'll mix some up tomorrow....thanks.
Old Oct 3, 2003 | 11:12 PM
96bronco58's Avatar
96bronco58
I just pulled the drive shaft on mine.(96 bronco) You canuse a 12 point 12 mm socket with a 3 in extension on the rear, but will have to use a box end 12 point at the transfer case if you want to remove it. There isn't enough room at that end for a socket to fit. Mine were torqued pretty tight propably around 60-80 ft lbs.
Old Oct 4, 2003 | 06:13 PM
Freakazoid!'s Avatar
Freakazoid!
I had to put about fives stars worth of torque on to get mine undone. But then I couldn't get it to stay together! Problem solved with a bunch more torque and some red loctite. I am dreading removing the thing again next week to swap the tranny.
79str8six
Mar 2, 2012 07:01 PM
crushtheogre
Feb 11, 2012 08:24 PM
PPrash
Mar 24, 2010 10:15 AM
BigF350
Mar 8, 2010 11:51 AM
Hanoverfiste
1997 - 2003 F150
Aug 28, 2009 09:36 PM
