Budget Injectors?
Old Jul 12, 2017 | 10:55 AM
2fifty's Avatar
2fifty
Budget Injectors?
Well my 7.3 has 317k on stock injectors and im looking into replacing them. Since im a cheap *** I was wondering if having my stock injectors upgraded to 175cc would be a good idea (it would be accompanied by a tuner).
I would like to go with a single shot injector but they are a lot more expensive than it would be to my stock ones upgraded.
Old Jul 12, 2017 | 11:10 AM
knottyrope's Avatar
knottyrope
do you have efuel, intercooler, hi output HPOP?
stage 2 is liked by a lot on here
Rosewood Diesel Shop
Old Jul 12, 2017 | 11:38 AM
2fifty's Avatar
2fifty
This engine is a complete virgin. Nothing but oem stuff was ever used. Would I need all those things to support 175cc injectors? I've read that you usually just need a tuner to go with the injectors and it'll run great.
And would having the stock split shot injectors modded to be 175cc be a good idea or should I just invest in some new injectors?
Old Jul 12, 2017 | 12:01 PM
z31freakify's Avatar
z31freakify
Do you have Cali emission truck? They can still make them to single shot injector, tuning will take care of the single shot.
Old Jul 12, 2017 | 02:56 PM
Jarrett Campbell's Avatar
Jarrett Campbell
x2 on rosewood. Great guys there and awesome products.
Old Jul 12, 2017 | 03:25 PM
knottyrope's Avatar
knottyrope
Stock fuel pump wont provide enough pressure with bigger injectors
with out an intercooler, you wont run long with a lot of power that makes more heat especially towing
HPOP stock wont handle the bigger injectors at full output
Rebuilt is going to be cheaper than new. Jim rebuilds them with a warranty as good a new warranty and everyone here likes his service and I will go with him when its my time.
maybe you need to figure out how much HP you want and how much you can afford
Old Jul 13, 2017 | 12:40 AM
2fifty's Avatar
2fifty
who does the stock split shot to single shot conversion? Will any old tuner do? What cc would you recommend for a truck that will just have a tuner, 4" straight pipe and an intake?
thanks for the help and advice so far!! (Sorry for all the questions, im new to diesels and relatively new to trucks in general)
Old Jul 13, 2017 | 07:04 AM
Jarrett Campbell
Do you have a Cali truck?
You can use any tuner but will need custom tunes to run the not stock injectors.
Rosewood can rebuild your injectors to stage 1, 160 cc, stock nozzle. That is a good upgrade.
Go to his site that was posted by knotty on post#2 and read up!
Old Jul 13, 2017 | 07:51 AM
2fifty's Avatar
2fifty
Not a cali truck thankfully
Old Jul 13, 2017 | 12:55 PM
Jarrett Campbell
In that case, you already have single shot injectors. 90cc.
Old Jul 13, 2017 | 02:58 PM
2fifty's Avatar
2fifty
So would I be able to get away with the cheap rosewood upgrade? the truck has 317k and the PO said they were stock injectors
also what supporting mods would be required to run those modded injectors without issues?
Old Jul 13, 2017 | 03:16 PM
Jarrett Campbell
You could get Rosewood's stage one injectors, plug them in your truck, and it would work fine with no upgrades. You would only be using 90cc of the available 160cc though because the truck's computer doesn't know that there is a bigger injector in there.
Therefore, if you want to realize the full potential of your new stage 1 injectors, you'll need to get a chip (either TS6, Hydra, or whatever you end up getting) with custom tunes that use all the available injector capacity. There have been some users that just used "canned" tunes on their TS6 chip with stage 1 injectors and it ran just fine, so it really is up to you.
As far as any other mods, the essential list is:
3" downpipe
Catalitic converter delete
gauges: EGT, Fuel pressure, Trans temp, and boost
Recommended:
E-fuel
Intercooler
Pretty much in that order.
Old Jul 14, 2017 | 03:56 PM
iverger's Avatar
iverger
If you tow, be careful. Even little upgrades can be a slippery slope.
I'd spend on the gauges 1st if you haven't already, you need a baseline. My 97 had 200K on it last year when I upgraded to Baby Swamps (150/146) and had my TS-6 chip reprogrammed accordingly.
I have a very healthy truck, fresh stock fuel system (65 PSI Idle, 40+ at WOT), S&B Air box, fresh coolant and filtration system, 3" Downpipe with 5" exhaust. New boost boots and upgraded clamps and no up-pipe leaks.
In tow/haul tune with just a 7k holiday trailer I have to drive by the EGT gauge here in East TN. All sorts of boost and power but hot. So now it's on to Intercooler and E-Fuel as mentioned earlier, probably a turbo rebuild/upgrade at some point as well.
All I'm saying is it's fun but there will be more. If you don't tow you still need gauges but you can get away with a lot more.
Good luck with the choice.
Bob
Old Jul 14, 2017 | 07:36 PM
oldbird1965's Avatar
oldbird1965
Then there is water injection to help control the 'hot'!
Old Jul 17, 2017 | 08:30 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
We rarely get to do a "cheap" Budget Build on the older injectors. Most are in pretty poor shape when we see them.
If you want to attempt the Budget Build, send them in, we'll get them apart and let you know what we find. But you should at least be prepared for a Premium Build. Or live with injectors in poor condition if you can't afford to fix them properly if needed.
I don't charge any more for the Stage-1's upgrade over stock, because I feel it's a great upgrade for the older trucks, even with minimal other mods.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
bowranger
17
Apr 15, 2014 05:55 AM
andres0517
17
Feb 12, 2013 03:09 PM
dthompson
Nov 13, 2010 12:59 PM
76cougar74100
Mar 29, 2010 09:01 PM
bigsteve1969
Dec 14, 2009 07:40 PM
